SUPPORT OUR SPONSOR
Old 03-02-2006, 05:07 AM
Speedysnake's Avatar
Cobra Make, Engine: BDR - 351 / 385 hp
Default Correct anti-sieze?
I went shopping for anti-sieze compound. Having limited experience with aluminum components, I read the labels on a bunch of products and am now totally confused. I'd appreciate everyone's thoughts on the best all-round anti-sieze that will work on the aluminum heads, spinners, etc.
Thanks in advance.
Speedy
Old 03-02-2006, 07:12 AM
Zoom This's Avatar
The Permatex product in the grey/silver can is what I use. It comes with a brush inside to make it a little easier to apply to your spinners without getting it all over your hands. In my opinion, the trick is to not see how damn hard you can bang on your spinners. If you keep laying into those spinners whack after whack with the lead hammer after they have made contact, no anti-sieze will save you.
Old 03-02-2006, 07:24 AM
Cobra Make, Engine: Three Cobras, one 351W, one 427SO, one 527BB & one GT-40 427R
Default try Spinner Eaze
You will definitely want to try this anti-sieze out...
http://performanceunlimited.com/cobr...innereaze.html
You need very little, is nearly inviosible and won't wash off the parts.
/Randall
Old 03-03-2006, 04:20 AM
OK, I guess I didn't phrase my question well enough; I have very little experience with aluminum engine components. I want to check the spark plugs, which I assume were installed by Ford when the engine was built. What, if any anti-sieze should I use on the plugs when I reinstall them in the GT 40 heads? And would the same product be acceptable for other aluminum applications on the car?
Thanks to the guys that did respond to my first note.
Speedy
Old 03-03-2006, 06:14 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I use Copslip ( I am not sure about the spelling ) on the threads for spark plugs and any other 'electrical to ground' device. It is a grease that is imbedded with copper balls ( very very small ). It works great for me.
Just my $0.02
Old 03-03-2006, 08:36 AM
Default Same stuff!
Speedy, the Spinner Eaze will also work GREAT for plugs in alloy or iron heads! It has a *very* high heat resistance and hold up very well and perform even better.
/Randall
HTML code is On
