SUPPORT OUR SPONSOR
Old 03-08-2006, 06:08 PM
Cobra Make, Engine: Midstates - 390 FE
Default Tie rod end problem
I have a Mustang II frontend and when I try to tighten the tie rod end castlenut the entire shaft is turning. I could sure use some suggestions on how to stabilize the shaft in order to get the nut tightened. Any help would sure be appreciated.
Thanks!
Old 03-08-2006, 06:50 PM
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
I have used a small hydraulic bottle jack with a soft block of wood as a cushion between the jack and the bottom of the tie rod end. Gently apply pressure with the jack as you begin to tighten the castle nut. You should reach a point where the nut turns and the tie rod end stops turning.
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
HTML code is On
