SUPPORT OUR SPONSOR
Old 03-28-2006, 01:35 PM
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
Default Anyone know how......
Anyone know how to remove the FORD style brake light switch? It's attached to the pivot pin for the brake pedal and it retains the master cylinder plunger and the pedal as well. It slides on the pedal pivot but it won't come off because the angle on the master cyl plunger rod is too great and it won't allow enough movement to slide off the end of the pivot.
Does this make ane sence to anyone?
I wish I could attach the picture but I was unable to so.
Old 03-29-2006, 04:00 AM
Roscoe's Avatar
Yes! I know how....
Roscoe
Old 03-29-2006, 04:53 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
You have to remove the pedal.
Old 03-29-2006, 05:11 AM
Clois Harlan's Avatar
Roscoe,
You're B A D, Shame on you!
"Let's roll"
"Be part of Something Good
Old 03-29-2006, 07:58 PM
Club Cobra Member
Thanks to all for your support. On the Classic Roadster, or at least on mine you cannot remove the pedal because you have to remove the pivot bolt and it hits part of the firewall before you can get it all the way out. I had to dissassemble the pedal set from the master cylinder. All this because the gas pedal was bent.
Display Modes
HTML code is On
