| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
04-06-2006, 07:45 PM
Ca
Baby steps/Webers in the future
I have been slowly gathering and fabricating the pieces necessary to add Webers to my 289. I have a NOS unmounted Manifold and just finished the fabrication and welding of the fuel/water manifold today.
[IMG]  [/IMG]
Rick
Advertising
04-06-2006, 08:11 PM
TX
Love the weber intake.........Where the heck did you find it?
Gary
CAV GT40
04-06-2006, 08:17 PM
Administrator
Wa
Rick, I fixed up your post so both photos would show. I love bits you fabricated.
04-06-2006, 08:31 PM
CA
Awsome! Better hide that thing good! I'm coming to get it
Hyde D. Baker
Ca
Thanks Brent, I couldnt get it to include both photos. What was I doing wrong?
Rick
04-06-2006, 08:38 PM
Administrator
Wa
Just looked like a cut/paste error as the second photo had two img tags on both front and back of url to the photo.
04-08-2006, 01:38 AM
FL
Cobra Make, Engine: genuine 289 cobra (cox 6013)
[IMG]  [/IMG]
Rick,
Very good job,tested the same and observed some trouble with heat transfer from water to gas (boiling)
Regards
04-08-2006, 09:12 AM
VA
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Rick:
I have a set of Weber 48 IDAs that I am about to put on Ebay for sale. Let me know if you are interested before I do. Thanks.
04-08-2006, 09:29 AM
Charter Club Cobra Member
OR
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
Reversing Plates
Rick,
To save yourself a ton of trouble with linkage consider fabing or buying a set of reversing plates for that manifold. If all the carbs are mounted in the same direction linkage is much easier to build and adjust.
I will be working on my linkage most of the day, I will try to take a few photos as I progress.
Scott S
Working as hard as I can every day to double my carbon footprint.
04-08-2006, 09:52 AM
Ca
We could really get crazy and use spilt Dominators!
Rick
04-08-2006, 06:45 PM
OR
Weber linkage
I worked most of the day on this between honey do's and it seem to to work real well. I purchased all the linkage pieces from Pierce Maniflods. http://www.piercemanifolds.com/linkage.htm
I used only one idle screw for the entire system and by adjusting it all the throttle plates move in unison. I also used throttle stops on the front passenger and the rear drivers carbs and disconnected the return springs on the two others.
Scott S
04-08-2006, 10:27 PM
CA
Nice setup, Scott! That linkage set should work perfectly! I'm looking to change mine. I'm not happy with it...
Rick, got my parts together & have a guy who can put the ridge in the inlet/outlets. I spoke to Lynn Parks today about his Y-Manifold. I asked him if he ever had a problem with fuel boiling. He told me that he has not had a problem with that & also said that he is always moving (racing) so there is always air moving past the fuel log. He also does not use a thermostat, rather a restrictor plate of some type.
Hyde D. Baker
HTML code is On
