Whats the trick to getting knock off knocked off?
I have been wailing on one wheel for about 45 minutes with a 3 lb ish hammer and it has not moved an inch. This is BDR 340# with about 150 miles on it. Im hitting it in the right direction, but im getting tired and i was hoping to get the wheels balanced this afternoon, any suggestions please/
Thanks a lot david |
When you get it off and , if you have not already done so, thin....thin...application of never seeze (spell) on the threads and mating surfaces.
I use a 3.5 foot 2x4. Put one end on the spinner and blast way on the other. That way I am standing up and can get a good angle on it and not have to worry about banging up the wheel or fender.
David, if one is slightly seized on, try hitting it the other way for a few wacks to break it loose, also check the threads and which way they are going as I had a "XXX" Cobra replica I was helping on that actually had a splined thread that was incorrect for the side it was on and while tring to remove it, discovered that sorrid fact (this is the only time I have seen or even heard of such a thing)...After you have checked the threads and which way they are turned/cut, spray a little WD40 on the threads and give it time to soak in, then work it back and forth a bit but hitting the ear both ways if you have to...
Hope you find this helpful. Sincerely, Bill S. |
...I have to ask: Your wheels are on the ground, right? ..not up in the air. |
Try one of FinishLine's knockoff wrenches. They're expensive (around $300), but they work well.
Are there lugnuts between the spokes?
Thx guys, yes the car is on the ground :), there are no lug nuts in the way either.
i will try the suggestions you have offered, now i got my breath back thx for the quick responses cheersw david |
As JBCobra previously mentioned, I too use a 2x4 along with a regular size sledge hammer. I am not sure a 3lb hammer is enough weight. You should be able to hold the 2x4 in one hand and the sledge hammer in the other. You will find it necessary to choke up on the hammer to control the swing and have the wrist strength to swing it one handed. The good thing is the added weight doesn't need to be swung around much and you end up allowing the hammer to do the work. There is no need for a big windup swing. Move the 2x4 around and hit the different ears on the spinner if need be. As suggested, make sure to use anti-seize when putting back together again.
Mark |
OK, im going up to home depot to buy a sledge hammer, i wont have to hit the gymm tonight, this is quite a work out.
Thanks everyone cheers |
Are you POSITIVE you are striking the threads in the correct direction?
The only reason I ask is the same thing occoured with me on an old british sports car. Earlier in its life someone had transposed the splined hubs while the drums had an inidcator arrow showing "loosen" in the wrong direction. |
The 3lbs. hammer is sort of light. We use the 5lbs. here and end up replacing them every 4th car or so it seems. They basically explode from the amount of striking it requires.
You can apply your gym membership elsewhere in the budget now ;) |
well, 10lb sledge hammer is destroying the 2 x 4 but the wheel hasnt moved an inch. tried liquid wrench and wd 40, covered the spoke in duct tape and a cloth to protect, but the thing isnt moving, thanks everyone for your help, not sure what i need to do now though
cheers |
im working on the passenger side of the car and hitting the spinner in a clockwise direction as it is left hand threaded that side of the car, so im pretty sure that is the right way.
once again, thanks everyone for your help, going to get soem protein in my system and give it another go :) |
When you say "10lb sledge hammer is destroying the 2 x 4" are you placing the 2x4 in a horizontal position or vertical position?
I have the 2x4 vertical as if I am driving a stake into the ground; the spinner ear is playing the part of the ground. In the vertical position the 2x4 transfers all the hammer energy straight down. If you have the 2x4 in a horizontal position, then only a portion of the energy is transferred to moving the spinner ear, unless the hammer is striking the wood immediately above the ear. However I would find this difficult to do without the hammer accidentally striking the fender on the down stroke, ouch. |
Thanks again, unfortunately the spinner position does not allow a straight vertical shot at it, it is halfwat between vertical and horizontal, i will try another wheel that may have a spinner in a more favorable position, i really thought i would be driving the car this weekend, guess not :(
cheers again |
I haven't heard of the 2x4 trick, have to file that one away. I change wheels often enough that I haven't had this issue.
Any port in a storm, as seen recently on CSX2085 http://www.clubcobra.com/photopost/d...ingSVRA504.jpg |
Sorry about the confusion. Not that the spinner has to be vertical or horizontal position, I was referring to the piece of wood and how it was being struck. When I hit the wood 2x4, I am striking the end of the board on the butt end, like a nail head. What I meant about hitting the 2x4 horizontally, would be hitting the side of the 2x4 as if it was laying flat on the ground.
I will have to take it to the shop i think, i now have 3 new hammers in my collection including a 10lb sledge hammer! I have spent about 5 hours trying to remove one wheel. im not to bad mechanically, i service my own race motorcycle but this is just v frustrating.
thanks everyone though |
When you finally get that spinner off, do yourself a favor and get the big lead hammer, wire and never seeze from these guys. That hammer really does the trick on my wheels!
http://performanceunlimited.com/cobr...ls/hammer.html Tim |
| All times are GMT -7. The time now is 06:22 AM. |
