SUPPORT OUR SPONSOR
Old 07-23-2006, 12:20 PM
Cobra Make, Engine: EverettMorrison,408W,Jag rear, toploader
Default Jag rear problem
I went for a ride a couple weeks ago and all of a sudden the car wasn't putting any power to the rear wheels. I pulled the differential out of the car and discovered bolts that hold the clutch and spider gear assembly together had come loose in the Power-Loc differential. Could this have happened for any other reason than not being torqued properly?
See picture in my gallery
Also, while I have this out of the car can anyone tell me if they upgraded to Wilwood brakes after having the standard Jag inboard brakes, and if there was a worthwhile improvement to braking.
Thanks in advance
Jerry
Old 07-23-2006, 03:54 PM
Tom Wells's Avatar
Yo Jerry,
Here's the guy you need to put that question to: http://www.cwiinc.com/index.html
The owner's name is Mike Bontoft and I'd take his answer to the bank
Tom
Old 07-23-2006, 07:07 PM
Cobra Make, Engine: ERA 377 - 428SCJ
As long as the rear end is our and needing work I would consider a pair of Mark Williams stub axels. They are built from better material and have quite a few more splines on them. The Jab stub axels in my car were twisted pretty badly and fortunately that was discovered before a failure that would have been very unpleasant.
Terry
Encino CA
ERA 377
428SCJ
Old 07-23-2006, 07:46 PM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
Originally Posted by hoppy
The Jag stub axels in my car were twisted pretty badly and fortunately that was discovered before a failure that would have been very unpleasant.
Very unpleasant indeed... These are a switch to get out after it comes to this.
Looking at the picture you posted, I have a hard time believing those were torques properly when assembled.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
HTML code is On
