Old 09-16-2006, 02:15 PM
Cobra Make, Engine: Kirkham 427
Send a message via AIM to jpfletch1 Send a message via Yahoo to jpfletch1
Default Erratic temperature gauge
I have been breaking in my car this weekend. It has a 482 aluminum engine. I am puzzled by how erratic the temperature gauge is. When going down the freeway at 2200 rpm in fifth gear the temperature gauge will be at 90°C and then jump 110°C and then fall back. I can't figure out why the temperature would change back and forth so rapidly. It seems like the gauge should gradually move up and gradually move down. Any ideas?
Old 09-16-2006, 02:28 PM
wtm442's Avatar
Beam Me Up Scottie
Sticking gauge if its mechanical or large air pocket in motor.
While driving, tap the gauge and see if the pointer jumps.
Warren
Old 09-17-2006, 06:28 AM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
If it's electrical check to make sure the threads aren't gunked up with tape or thread sealer. You need a path to ground.
Bill Stradtner
Old 09-17-2006, 06:38 AM
392cobra's Avatar
6th Generation Texan
Thread sealant shoudn't be used on the electrical sender that goes into the intake manifold ?
Old 09-17-2006, 04:53 PM
Watch out for a pluggeg thermostat by pass. that little fost from the intake manifold to the rear top center of the coolant pump. It keeps coolant circulating..
Mike H
Old 09-17-2006, 05:17 PM
Cobra Make, Engine: ERA
low coolant? air pocket? try filling coolant with front end on incline.
Old 09-17-2006, 05:56 PM
392cobra's Avatar
Originally Posted by 392cobra
Thread sealant shoudn't be used on the electrical sender that goes into the intake manifold ???
TTT
How about sealant in regards to an electric oil pressure sender too ???
Old 09-18-2006, 09:17 AM
Zoom This's Avatar
Could be your themostat. When I watch my temp gauge it will fluctuate very slowly between 75 and 78, back and forth while driving on the freeway. In my case, it's just the thermostat closing and reopening just a little.
