SUPPORT OUR SPONSOR
Old 10-04-2006, 12:22 PM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default Ford clutch help
When using a stock Ford 351 clutch, how far does the pressure plate tangs move inorder to disengage. My tilton HTB is moving about 3/4 in and just "barely
releasing the clutch. Help!!
gn
Old 10-04-2006, 02:26 PM
ENTDOC's Avatar
should be enough Grover, I wonder if your HTB is adjusted out far enough.
Old 10-04-2006, 03:58 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
3/4 inch is what it is supposed to move ( it is how far mine moves on my 351 ). I actually had to put in a stop.
Is there play at the front end? Adjust the slave rod until the TO bearing is just touching the pressure plate fingers, you should be okay.
HTML code is On
