Old 10-08-2006, 10:53 PM
Cobra Make, Engine: Midstates/Antique Collectable
Default Floor Mount Pedals?
I am thinking of going with TILTON or WILWOOD floor mounted pedals. I was going to fabricate a 2" drop to my pedal box and add a 1/4" plate across the bottom for mounting the pedals. I am 6'1" and feel this style pedals will be stronger and more comfortable. Are there many others that have gone this route? Any info on floor or hung pedals wil be greatly appreciated.
Bruce
Old 10-08-2006, 11:30 PM
ERAs come with floor mounted pedals, using Tilton master cylinders, one for front and one for rear, mounted side by side with a simple balance bar connecting them to the pedal rod for easy front/rear bias adjustment.
Do you fit in the car with the standard (not dropped) floor? If so, this type setup works well.
Dan
Old 10-09-2006, 12:06 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
My Arntz is fitted with floor mounted pedals with the masters under the floor.
The assembly is mounted in a way so that the whole pedal assembly can be slid front to back to adjust for drivers of different leg lengths.
There is a removable aluminum plate for the floor which makes adjustment and bleeding very easy.
The car originally had all Hurst/Airhart masters with built in resevoirs, but I have swapped the clutch master for a Tilton using a remote mounted resevoir.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 10-09-2006, 06:29 AM
Roscoe's Avatar
I mounted these in my A&C.
Roscoe
Old 10-09-2006, 08:25 AM
Send a message via AIM to mj_duell
We use Tilton 3 Pedal assemblies on our EVO 5 chassis. I like the spacing and feel.
--Mike / Turn Ten Racing, Inc.
Old 10-09-2006, 10:20 PM
Hey Mike & Roscoe how much of the master cylinder protrudes the foot box? I like the Tilton setup. Mike do you sell this setup?
Old 10-10-2006, 03:13 AM
Hi Bruce,
We do not sell the set up separately, but you can buy it here and other places on-line:
http://www.hrpworld.com/index.cfm?fo...action=product
The master cylinder length is about 5.5 inches, but you can get "shorties" from tilton which I beleive are around 3.5 inches.
