SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-30-2006, 07:54 PM
Cobra Make, Engine: Superformance 351/427 stroker
Default Is there supposed to be a gas cap under... the...
the quick release Lemans cap?
Old 10-30-2006, 08:02 PM
Cashburn's Avatar
Backdraft Racing Dealer
Yes. Depends on manuf. but there should be one there... on one car I once saw a bathtub/sink type plug. I think it was a CMC.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 10-30-2006, 08:05 PM
Aussie Mike's Avatar
I reckon it's a good idea to run a sealed cap under the Lemans cap and have a carbon canister to take care of the venting. I'm running a sealed filler cap under my lemans cap. I'll try to find a picture.
Mike Murphy
Melbourne Australia
Old 10-30-2006, 08:15 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
Mine does not. There is a rubber gasket that seal the Lemans cap to the filler neck.
Old 10-30-2006, 08:33 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Nope, don't have one either, but like Jay said, it depends on the manufacturer.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 10-30-2006, 09:07 PM
Cobra Make, Engine: Kirkham #259
Like this Gas cap in a Flip cap that does not seal.....
Morris
Old 10-30-2006, 09:10 PM
With this set up and the two vents...... we can fill as fast as a 2" line will go.....
Morris
Old 10-30-2006, 09:28 PM
HI Cobra's Avatar
I know of someone here in Hawaii who uses a tennis ball that seems to
work just fine.
Flip
Old 10-30-2006, 11:09 PM
wtm442's Avatar
Beam Me Up Scottie
My SPF has a nice locking gas cap under the LeMans cap
Warren
Old 10-31-2006, 08:03 AM
Roscoe's Avatar
The tennis ball was used on the track back in the early days of racing the Cobras. I've used the same one for 7 years and it works fine as an anti-slosh valve. You should see the look on the gas station guys face when I take it out.....the tennis ball that is.....
Roscoe
Old 10-31-2006, 09:25 AM
Greg Haile's Avatar
Cobra Make, Engine: Everett Morrison 460
I chose the locking cap to keep kids and unscrupulous characters at car shows from getting into trouble.
Old 10-31-2006, 09:28 AM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Mine doesn't have one. There is a rubber seal in the Lemans cap.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 10-31-2006, 09:37 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
seems like hair ,fuzz and junk would come off the tenis ball after a while. no? does the cap still seal? I sure would like to stop all the fuel drips in and around the cap(down the back) when my tail does the wiggllie (the car i mean).
the older i get the faster i was.
Old 10-31-2006, 11:09 AM
The LeMans type of cap has a tendacy to leak when going around corners.....
Especially if you put the car on a track......
The other issue is filling the fuel cell quickly ...... so you put the cap in below the LeMans cap...... and then use the space between the caps as the vent area...... and drill some holes in the sealing plate of the LeMans cap to vent the fuel system thru the LeMans cap............No leaks
Also..... when you are filling the fuel cell .... the vents will start spitting at you when you are almost full..... and they just spit back into the fuel fill hole....
Morris
Morris
Old 10-31-2006, 12:02 PM
Cobra Make, Engine: Backdraft 351W Balanced/Blueprinted 360HP / Tremec 5 Speed
Mine has a locking gas cap under the flip top lemans cap...ox_ford_guy
Old 11-14-2006, 02:38 AM
wtm442's Avatar
Beam Me Up Scottie
Here are pics of the SPF setup
Warren
HTML code is On
