01-24-2007, 09:30 AM
6th Generation Texan
TX
Lock Cylinder Replacement
1964-1969
1. Insert key and turn to Acc. position.
2. With stiff wire in hole,depress lock pin and rotate ccw,then pull out cylinder.
Ignition Switch Replacement
1964-1969
1. Remove cylinder as above.
2. Press in on rear of switch and rotate the switch one-eighth turn ccw .Remove the benzel,switch and spacer.
3. Remove nut from back of switch.Remove the accessory and gauge feed wires from accessory terminal.Pull insulated plug from rear of switch.
4. If this fails..a cut off wheel will work.
