SUPPORT OUR SPONSOR
Old 02-19-2007, 09:03 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Default Weber gurus
Do you need to disconnect the throttle linkage between the front and rear carbs before you can get the carbs to flow the same kg/h? When I first put the weber set on a few weeks ago I didn't have a problem and never messed with the interconnect linkage between the front and rear carbs and I had equal flow through all carbs but do to a head and intake gasket leak I had to pull everything off and start all over again
My 2 front carbs are flowing about 2.5kg/h while the rear carbs on both sides are flowing 7kg/h...
Any ideas or help ?
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
HTML code is On
