SUPPORT OUR SPONSOR
Old 04-11-2007, 11:03 PM
Rick Parker's Avatar
Default Tool Definitions
These are very accurate definitions of tools from my experience.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar
stock out of your hands so that it smacks you in the chest and flings
your beer across the room, splattering it against that
freshly-stained heirloom piece you were drying.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and
hard-earned guitar calluses from fingers in about the time it takes
you to say, "Oh sh--...."
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of
old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood- blisters. The tool most often used by all women.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs
into major refi nishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle.
It transforms human energy into a crooked, unpredictable motion, and
the more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If
nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
WELDING GLOVES:
Heavy duty leather gloves used to prolong the conduction of intense
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your
shop on fire. Also handy for igniting the grease inside the wheel hub
you want the bearing race out of.
WHITWORTH SOCKETS:
Once used for working on older British cars and motorcycles, they are
now used mainly for impersonating that 9/16 or འsocket you've
been searc hing for the last 45 minutes.
TABLE SAW:
A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have
installed your new brake shoes, trapping the jack handle firmly under
the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4:
Used for levering an automobile upward off of a trapped hydraulic
jack handle.
TWEEZERS:
A tool for removing wood splinters and wire wheel debris.
E-Z OUT BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill bit that snaps neatly
off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW:
A large stationary power saw primarily used by most shops to scare
neophytes into choosing another line of work.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you
forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER:
A very large pry bar that inexplicably has an accurately machined
screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
TROUBLE LIGHT:
The home mechanic's own tanning booth. Sometimes called a drop light,
it is a good source of vitamin D, "the sunshine vitamin," which is
not otherwise found under cars at night. Health benefits aside, its
main purpose is to consume 40-watt light bulbs at about the same rate
that 105mm howitzer shells might be used during, say, the first few
hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids and for opening
old-style paper-and-tin oil cans and splashing oil on your shirt; but
can also be used, as the name implies, to strip out Phillips screw
heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common
slotted screws into non-removable screws.
AIR COMPRESSOR:
A machine that takes energy produced in a coal-burning power plant
200 miles away and transforms it into compressed air that travels by
hose to a Chicago Pneumatic impact wrench that grips rusty bolts
which were last over tightened 30 years ago by someone at Ford, and
instantly rounds off their heads. Also used to quickly snap off lug
nuts.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent
the object we are trying to hit. Women primarily use it to make
gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE:
Used to open and slice through the contents of cardboard cartons
delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially
useful for slicing work clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while
yelling "DAMMIT" at the top of your lungs. It is also, most often,
the next tool that you will need
Now be honest...........you have at least ONE of these! LOL
Rick
Old 04-11-2007, 11:29 PM
Brent Mills's Avatar
Administrator
This is great stuff! This must be going around the net big time, as someone at work sent this to me in mail today.
Old 04-12-2007, 02:52 AM
52chevyred's Avatar
Cobra Make, Engine: Street Beasts 302 HO
That's the best "desk reference" I've ever seen.
52chevyred
Old 04-12-2007, 04:49 PM
Seasoned Member
Cobra Make, Engine: Unique 427 S/C, Dart 427W "Replica" Ford engine
For those hard to find tools and custom parts, check out these guys:
www.kalecoauto.com.
Bill stradtner
Display Modes
HTML code is On
