SUPPORT OUR SPONSOR
Old 04-25-2007, 09:55 AM
Default Msd
There is a reason NASCAR teams have two boxes and a switch to select a different system, they fail. MSD took forever to go from analog to digital and there design and construction was not the best in older models. I understand that the newer digital designs are using more modern techniques and are less prone to failure. All the electronic systems do provide quicker starts, and much better ignition performance than the old points and coil systems.
Old 04-26-2007, 03:53 AM
Default MSD 6AL box
Lineslinger I have had 2 Msd boxes go bad. First was from a welding bracket on the car. I didn't unhook the power and it blew the box. 2nd was the ground wire connection was weak, and cooked the box. Both where repaired from MSD with no problem and no charge, on shipping. Since I have learned these lessons no problem. I do carry a spare with me. My whole ignition system is MSD. I mounted my box under my glove box, next to my ECU. They are kept clean and dry. The air flow that comes from the front of the car for the foot box blows on both modules. No other problem at this time, but a do carry spare box, crank sensor, and distributor module, Coil I can get local at any speed shop or Auto-Zone. Rick Lake ps carry basic tools to change this also.
Old 04-25-2007, 09:33 AM
6AL user here. I had a bad one right out of the box....swapped it out and haven't had a problem since. I also use their coils, dizzy's, and plug wires. Pretty pleased overall.
Would use them again.
Old 04-25-2007, 10:46 AM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Thanks for the information, now, what kind of dollars are involved with those accessories, expensive?
Old 04-25-2007, 10:50 AM
The capacitor is $40 and the rev limiters are $60.
Old 04-25-2007, 10:52 AM
Appreciate your help.
Old 04-25-2007, 11:02 AM
Banned
I personally believe that the whole MSD flap is more urban legend. They have done a lot in the way of quality control from their earlier days...that's probably when they experienced the most problems. I thought my unit went bad, too. Had MSD load test it and it was fine. Traced the real problem back to a bad (loose) ground wire. I run a 100% MSD solution...billet distributor, high vibration coil, wires, etc. Car starts and runs good. I believe most MSD issues are related to other electrical problems independent of MSD (as has been outlined on this thread quite a few times, i.e. bad ground, bad voltage regulator, etc.).
-Dean
Old 04-25-2007, 11:27 AM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
MSD was bought out by a private equity firm a year or two ago. These deals rely hevaily on debt to fund the majority of the pruchase. You can bet that expenses are being more closely watched to help make the debt payments. In terms of increased failures I have no direct knowledge. My 6AL has worked fine for 8 years. I have noticed that their distributor caps do not appear as durable as the old ones though. This is my opinion though and I have no tech to support it.
Old 04-26-2007, 09:16 AM
Igofastr's Avatar
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
I'm running an MSD digital 6. 2K miles and no problems. Mounted in passenger footwell.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
Display Modes
HTML code is On
