Old 05-10-2007, 05:32 AM
Cobra Make, Engine: SPF
Send a message via AIM to Tinker51
Default Adjusting pins for Trigo wheels
After some maint that required removal of the rear brake discs I am putting everything back together. What I am running into is the pins are not aligning with the holes in the wheels. I have the Trigo pin alignment tool and it slips right on when the pins are loose and as I work around the pins slowly tightening it fits fine until I put the final torque on them and then it does not. I searched some old threads on the subject and saw where some folks were just beating the wheel studs/pins into final alignment. Is this really the prefered method?
We have enough youth. What we need is a fountain of common sense
Old 05-10-2007, 06:57 AM
I don't have the Trigo tool, so what I did was a (very tedious) trial and error installation to determine which way the pin needed to go, and used a two-foot piece of pipe that just fit over the pin (3/4"?) and "coaxed" it in the direction it needed to go...that is a whole lot less stressful to the pin and stud, and worked like a charm, just not very quick...
Ken
