SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-10-2007, 10:26 AM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
Default Borgeson steering vibration damper.
Has anyone used this before? I'm wondering if this would help with the over 60mph vibration I get in the steering wheel.
Yes, I've had the tires road force balanced and the wheels checked. I believe just the little flat spot from sitting in the garage is enough to shake the steering wheel.
Vibration Damper
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 06-10-2007, 11:00 AM
Cobra Make, Engine: Shell Valley, 351W
I have the Flaming River equivalent. It works fine. Steering is tight and precise with no vibrations.
Sydney
Old 06-10-2007, 11:04 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
looks like a great idea. I allways am feeling something in the road and thinking something is wrong .Peace of mind is a good thing.
the older i get the faster i was.
Old 06-10-2007, 11:19 AM
The Flaming River unit is used by many with great reviews. Flaming River manufactures an entire line of steering related components of very high quality. I would go in that direction.
Old 06-10-2007, 12:17 PM
Tom Wells's Avatar
Jim,
I went the other way (what's new?)
I removed the 3rd u-joint in my steering shaft and discovered a new car! With only two u-joints the steering became more precise and responsive. It's great.
There was also a vibration that I had not noticed before.
Close examination revealed a front tire that had got flatspotted at Gainesville
New front tires made it perfect again.
The old setup hid the symptom.
My point is, if there's a vibration, maybe there's a reason
Just a thought,
Tom
Old 06-25-2008, 10:23 PM
Bartruff1's Avatar
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Default What is it that you have ?
Sydney
I don't see a steering damper product at their site ? What do you have ? Does it have a part s number ?
Old 06-25-2008, 11:27 PM
Rick Parker's Avatar
http://www.flamingriver.com/index.cf...=cat/cat79.htm
'zackly
Well said Tom...........
Rick
Old 06-26-2008, 04:02 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
I put one on my car a couple of years ago. The results are very subtle. I doubt it would make a significant difference if you have vibration issues. Precision alignment and balance is better. If you're running BFGs, they have a tendency to be a bit "inprecise".
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
HTML code is On
