SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-21-2007, 10:44 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default rear axle question
When I built my CRII I procured a rear axle from a 95 mustang. When I took it apart to clean up and paint I took a weight off of it that was attached to the diff near where the driveshaft comes into that axle. I never put it back on and found it while cleaning my garage tonight. Is it important? should I put it back on? If not will I blow up?
Old 07-21-2007, 11:54 PM
LMH's Avatar
LMH LMH is offline
This is the cast bracket that bolts on the under the front nose of the diff, right?
I read somewhere that it's called "monkey-balls" and no, you don't need it.
Unless you're a monkey!
Old 07-22-2007, 07:25 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
That's one of the devices added to cut down on the NVH(noise,vibration and harshness), it's is not a neccesary component.
WDZ
Old 07-22-2007, 08:53 AM
Yeah thats them.... Thanks guys...
HTML code is On
