02-05-2008, 11:07 AM
NV
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Exhaust heatshields
I am thinking about getting some exhaust heat shields & was wondering if they make much of a difference. They are pretty close to the actual pipes & I am sure they will get hot too.
Thanks!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
02-05-2008, 11:37 AM
Save your money. They get just as hot. Tell passengers to not get out till you come around to assist. As for your self, you get burned once and you never forget again. Regards Carmine
02-05-2008, 11:59 AM
They do get as hot, but they cool off quicker. Certainly not quick enough to get out of the car without care, but quicker than the regular pipes.
Dan in Arizona
CCX3209
02-05-2008, 12:06 PM
NV
Thanks guys! I will have to make a desision. I do like the way they look as well.
Thanks for the info!!
Rob
'65 BDR #126
'84 Porsche 928S
02-05-2008, 03:28 PM
Fl
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
I will have to disagree with carmine. I had BDR #123 with side pipe shields and I could come in from a drive and put my hand on the shields and the were very warm/hot to the touch but would not cause a burn.
On a bad day life is good. On a good day life is great. Enjoy life!
02-05-2008, 03:38 PM
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Have to agree with David...they DO indeed get hot and you CAN get burned, but not hot enough to give you the REALLY damaging burns that straight sidepipes do!
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
02-05-2008, 03:40 PM
FL.
Cobra Make, Engine: n/a
I am wondering if the louvered shields would dissapate the heat quicker?
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
02-05-2008, 03:44 PM
The louvered ones with all the holes cut out are the ones I have. Couple of my gallery pics show them.
02-05-2008, 03:47 PM
Regularly Offensive
I got mine from finishline. They have worked great. My legs are short and slow so it takes me a bit to get out of the car. No more burns no matter how long it takes me. I still have the scars from the first burns, and I might add my last........
Ed
Too close for missles, switching to guns.........
02-05-2008, 06:41 PM
CO
I have a set of solid ceramic coated shields. There's a definate improvement with them on. BUT, I think they're a little short. They leave a little too much of the end of the pipe expeosed. One of these days - in my copious free time - I'm going to do something about that.
02-05-2008, 07:02 PM
Cobra Make, Engine: BDR 930, 427 Windsor T56
If the proper technique is used for getting in and out of the car, your leg won't ever get close enough to the pipes.
Until you open the hood and start messing around under there.  Heat shields don't work for that anyways.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
02-05-2008, 08:07 PM
AB
Cobra Make, Engine: Butler Racing/427 side oiler
Ya I figure you will most likely get burned at some point if you own a Cobra... All my friends have been burned ..not me yet but I thought I was pretty smart till I opened my hood and being a dummy rested my arm on my upper rad hose and experienced a beautiful burn ...so moral of the story is BE CAREFUL and tell all that come around your car the same!
02-05-2008, 08:49 PM
AB
Cobra Make, Engine: west Coast Cobra FRP 460, Tremec 5 sp, Ford 9" rear
I have the heat shields with hundreds of tiny holes and they cool down very quickly. So i'd say they do add some protection. Cause no matter how many times you tell others to watch the pipes someone will always forget.
Brent
Get in,buckle up,hang on and scream all you want cause nobody's gonna hear you over the sidepipes!
02-05-2008, 08:53 PM
az
OK, just put the exhaust under the car.......
double ugly
02-05-2008, 10:22 PM
I had shields and I can say that they definatly work. They do get hot but a bare pipe burns as soon as you touch it,and with the shield not .
02-06-2008, 12:30 AM
They do work. I like the look. I did get them - but not for me. I just couldn't imagine my friends, wife or kids getting seriously burned. Do a search here - there are some pretty scary pictures of some very serious burns.
02-06-2008, 02:42 AM
VIC
Heat shields
I got mine after a little girl burnt her leg  on the pipe at a chariyt day fo kids with cancer.
the shields get fairly warm but not hot enough to burn or cause blistering.
cheers,
Bryan
VK3KDN
02-06-2008, 05:44 AM
Mine work really well. You have to install it using the kevlar strips to insulate it from the sidepipes, and as far back as possible. I've had a few shrieks from passengers but no burns.
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
02-15-2008, 10:56 AM
WA
I have the perferated SS heat shealds from Finishline. They get warm when the car is just sitting running , they are warm and in traffic and normal driving they are warm. I have burnt my ankle and scorched my pants on the bare pipes but never on the heat sheilds. The heatsheild temps will varry with the heat from the sidepipes and outside air temperature and flow over them. They are a clamp on deal, so it's not a life changing decision. You may want to change some of the hardware I used a lot of jam nuts to lock things up. Ny-locks and heat are not going to work. Self locking nuts(where the nuts are distorted) and stainless steel screws don't work . The soft stainless steel will gall ( transfer material) and then lock up permantly.
Mike H
02-15-2008, 09:55 PM
NV
I appreciate the info Mike! Thanks. I am still debating about them, but will probably get them. Right now I am waiting on my new Clutch master so I can drive my baby! Tired of seeing her in the garage!
Rob
'65 BDR #126
'84 Porsche 928S
