SUPPORT OUR SPONSOR
Old 03-14-2008, 07:55 AM
bigrob's Avatar
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Default Tach location
I finally got by baby on the road a couploe of days ago & noticed that I cannot see the tach very well. The steering wheel, combined with my seat moved all the way forward, causes an obstuction. I was thinking about swaping the tach & speedo. Even though the speedo is further away, I can SEE it!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
Old 03-14-2008, 08:06 AM
Default Another Solution
That's the main reason I put in a quick-release steering hub. When I drive I do not have my steering wheel aligned "perfectly straight" as it hinders my view of the gauges (I have it off by about 75 degrees or so). With a QR hub, changing the alignment of your steering wheel takes about two seconds. There's some other added benefits to having it as well, but if you think that might do the trick I'd recommend you go with that. Here's a shot:
Old 03-14-2008, 10:02 AM
I simply (well OK, it wasn't THAT 'simple') swapped the speedo and tach locations. I focus more on the tach and occasionally check the speedo reading. I know how fast I'm going based on rpm.
Old 03-14-2008, 10:52 AM
terry251's Avatar
Cobra Make, Engine: SPF Roadster, 418W
Can you rotate the tach enough to make the portion you most need to see visible?
Terry
Old 03-14-2008, 10:53 AM
wtm442's Avatar
Beam Me Up Scottie
I shift by ear! Its a lot easier and safer looking at the road at all times.
Warren
Old 03-14-2008, 11:53 AM
Originally Posted by Excaliber View Post
I simply swapped the speedo and tach locations...
Oh yeah, nothing to that little job at all. I'd rather put in a QR hub, at least you're working in front of you while sitting down instead of lying on your back upside down with your head jammed in a foot box....
Old 03-14-2008, 08:55 PM
bigrob's Avatar
I only drove my car briefly the other day, I have no plates yet. I need to check this out more closely. I will not be tracking the car, but I do want to know when I am getting up on the scale where I am in revolutions. I will be in her this Monday & I will see. Thanks for all the input!
Rob
'65 BDR #126
'84 Porsche 928S
Display Modes
HTML code is On
