Old 03-22-2008, 05:12 PM
Cobra Make, Engine: Midstates, 302 GT-40
Smile Got Gas?
Sorry, couldn't resist the title.
Well, my Cobra has been sitting in the garage for about 8 months. It ran fine back then but now it won't start...the fuel pump works fine and delivers gas TO the carb but I don't get any gas IN the carb...not sure why.
A buddy told me that the needles might be stuck...but again, I don't know much about carbs.
Any ideas?
Tom
Old 03-22-2008, 05:18 PM
GlynMeek's Avatar
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
sounds like your floats may be 'stuck'. You just need to take the carb apart and check. This shouldn't be a big issue, you should be able to solve whatever it is by a quick disassembly of the carb basics...simple 'sticking' issue since you haven't used it for a while.
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
Old 03-22-2008, 05:34 PM
I tried taking the carb apart...I loosened the 4 screws for the fuel bowl to get to the floats but it wouldn't come off. I didn't want to break anything (got a long history doing that) so I put the screws right back in.
How do I get the fuel bowls off? Also, is there a gasket between the fuel bowl and the carb body? And once I get it off what do I do with the floats? Just wiggle them??
Thanks again!
Tom
Old 03-22-2008, 05:49 PM
trs900's Avatar
Cobra Make, Engine: BDR # 165 392 Ford Crate 430HP
Try tapping side of carb with wood hammer or something similiar and just maybe you will get lucky and free the float.. probably the carb is gummed up
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
Old 03-22-2008, 05:58 PM
Yep, and squirt a little starter fluid down the carb and make sure the car runs, even for just a few moments.
