| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
04-14-2008, 05:40 AM
Ouch Ouch Hot Sand
FL
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Brake Light Switch Question??????
Safe Flyin, errrrr Drivin, Earl
Advertising
04-14-2008, 05:52 AM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by EarlsflyinCobra
Take the time and make the bracket for the switch.
I am running the hydraulic switch and it takes a lot of pressure to keep it on and it is a little late coming on at that.
I notice it will not stay on with my foot on the brake at a stop light unless I apply some good pressure.
I know all mt early Fords had the same set up but they were big iron.
I might changing the switch first to see if it is just the switch but I am still going to change mine over.
This conversion to a switch on the brake pedal is my next project.
What switches have you found that you like?
04-14-2008, 06:02 AM
..can't remember where I got it from.. but ...(CRS at it's finest  )
Now what was I talking about??  O yea, they make a hydraulic actuated brake switch which acts with minimal pressure, about a 6psi delta as I remember. With my old switch I had to stand on the bakes to get my lights to come on. At an intersection with light pedal action I always had no brake lights. With the new switch minimal pressure actuates the lights. As I remember the switch was about 20 bucks.. I'll see if I can dig up an old receipt or email about it..
Dave
Too many toys?? never!
04-14-2008, 06:24 AM
Ca
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
Talk to Mike Forte at www.fortesparts.com He sells a mechanical switch for use with the Wilwood pedal system. He also has a bracket that will integrate the switch with the pedals, but it's designed for use with a FFR chassis.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
04-14-2008, 06:40 AM
MD
Dave
Try to find the part number, please. I have a new switch in my parts cabinet that I was going to try. I will have to look but I think it is a low pressure one.
04-14-2008, 06:52 AM
I have used both systems. The low pressure hyd switches work well and I haven't had a failure in over 7 years and 60,000 miles of driving. Running one per system is good cheap insurance.
I have also used Fotes for other parts and have been happy with his components. Either way, have fun, and be safe! John
04-14-2008, 07:12 AM
CA
Earl,
I used the mechanical one for over 10 years and never had a failure. You never mentioned this, but I also used a neutral cut off switch so the car couldn't be started unless it was in neutral.
04-14-2008, 02:02 PM
Ron Francis wiring sells a low pressure brake light switch that's a redesign and supposedly works very well.
04-14-2008, 02:37 PM
TX
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Lonestar Classics Cobras come with the hydraulic switch, but overall the mechanical one looked far simpler and 'less messy' to install and has worked perfectly FOR ME! Had to fabricate the bracket, but what the heck, it IS a custom car...LOL.
Reading this thread (which I am sure has just started...lol), you've got about 50% for the hydraulic, and 50% for the mechanical...both work, and perceptions of complexity or difficulty will vary for both, so it pretty much comes down to personal preference I think!
Glyn
PS Ron...how did you wire the 'neutral' cut off switch? Is there an appropriate 'output signal' coming out of your transmission, somewhere. I have a T56 Tremec, and the only 'output' I can find is related to a 'reverse gear' solenoid!
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
04-14-2008, 02:43 PM
I checked and I bought it off ebay.. Here's the exact one that I got..
http://cgi.ebay.com/ebaymotors/Hydra...spagenameZWDVW
Dave
Reason: found the Ebay listing.
04-14-2008, 03:36 PM
MD
Thanks Undy
04-14-2008, 03:37 PM
Ga.
Same as John, low pressure switch and no problems. Auto mfg. used them for decades.
Perry
04-14-2008, 03:59 PM
PA
Cobra Make, Engine: Look-a-like cobra POS
NAPA sells those rare switches.
B. Ewing
04-14-2008, 04:18 PM
CA
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
You can get a hydro switch for a 78-84 VW rabbit/jetta and it works well at low pressures it is not very expensive
04-14-2008, 04:23 PM
PA
I believe the NAPA PN# is SL147. ~$13.
B. Ewing
04-14-2008, 04:31 PM
Not for $9.50 to your door step though..
04-14-2008, 04:43 PM
MD
Are they metric?
04-14-2008, 04:57 PM
CA
Are they metric?
Good question? I'm not sure
04-15-2008, 06:03 AM
Ouch Ouch Hot Sand
FL
04-15-2008, 06:08 AM
CA
Earl,
See post # 6.
HTML code is On
