Old 07-15-2008, 12:03 PM
Default Leak at bell housing - any ideas?
My Backdraft Cobra has a Ford Racing 347 with a Tremec 5 speed, and I recently noticed a slight drip of what appears to be coolant (?) down the outside center of the inspection plate on the bell housing.
After some cursory inspection, it is not obvious where the source of the leak is coming from. It doesn't appear to be coming from within the bell housing, but outside of it somewhere around the top of the oil pan. I checked the oil, and there doesn't seem to be any water in it.
Anyone experience a similar issue? Any ideas? Thanks in advance.
Sam
BDR #???
Old 07-15-2008, 12:26 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
You may have an intake manifold leak. Could be a head bolt?????
Old 07-15-2008, 12:28 PM
Ron61's Avatar
Post
Maybe check that your intake manifold is seated completely. I fought a drip in the front for almost 4 months before I finally decided to re-torque my intake bolts. That stopped the drip and I never did find exactly where is was coming from. But I have a feeling that the front seal across there in that corner wasn't seated and the bold had backed off just a tiny bit. After torquing them I never found another drip.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-15-2008, 01:21 PM
Thanks for the feedback. If the intake bolts need to be re-torqued, is there a sequence to go about doing this? And how do I know what the torque setting should be? Pardon my ignorance, but I couldn't find this information on the Ford Racing site.
Old 07-15-2008, 01:32 PM
Got the Bug's Avatar
Sam - You might want to buy an inexpensive fluorescent leak detection kit. I bought this one from Summit, but I think that Napa Auto sells something simlar at lower price.
http://store.summitracing.com/partde...5&autoview=sku
It comes with dye for oil and water and is pretty effective in pinpointing leaks.
Doug
Old 07-15-2008, 01:37 PM
Try re-torquing your IM with this as a pattern and 25 ft/lbs and see if you get lucky.
Old 07-16-2008, 10:12 PM
Thanks all for the feedback. Looks like I have a place to start. I'll reply with what I find.
Old 07-18-2008, 05:09 AM
Ron61's Avatar
GTB is correct about the leak detector. I have one that I got at NAPA and it works very well. I just add the dye to the oil or tranny and then drive it and after it sets the light will show any leaks very well.
Ron 61
Ronnie Widener
Old 07-18-2008, 07:02 AM
UPDATE: So I remove the air filter, and then I see coolant along the intake manifold gasket around the #1 bolt near the front. I check the #1 manifold bolt, and it is loose very loose. Break-out the torque wrench, and start tightening per the sequence. Started with 10 ft/lbs, everything OK. Then went to 15 ft/lbs, and the #1 bolt pops (other bolts were OK at 15 by the way). Luckily I was able to remove the broken #1 bolt completely (thank you GOD!!). So now a couple of questions:
- What should the torque setting be on these bolts? I was going to work up to 25 ft/lbs, but based on what happend, not sure anymore.. The manifold is a single-pane Victor Jr. (Ford Racing #M-9424-D302), and the heads are Edelbrock Victor Jr. Really having a hard-time confirming the torque values for these..
- Should I just replace the broken bolt, or replace the entire bolt set?
- What does this do to the torquing sequence? Do I need to loosen all and start all over?
- Or do I need to start from scratch and replace the gasket?
Suggestions??
Old 07-18-2008, 08:07 AM
sharpe 1's Avatar
Chances are the bolt that broke was over tightened at some time. I would replace them all based upon the one breaking. There may be more that are stretched to their limit.
Old 07-18-2008, 10:24 AM
Replace them all with quality bolts. For you to snap one off at 15 ft/lbs means the bolt is either defective or had really been torqued down hard by someone else. Either way you want to swap out that set.
Edit -- here are the PDF installation instructions for 2 Victor IMs, Ford and Chevy. Ford calling for 16-18 ft/lbs and Chevy calling for 25 ft/lbs. FWIW, I have my Blue Thunder on the FE torqued to 30 ft/lbs.
http://www.edelbrock.com/automotive_...7000/77169.pdf
http://www.edelbrock.com/automotive_.../2000/2978.pdf
Old 07-18-2008, 06:46 PM
Thanks for the feedback. Went out to the local spped shop and purchased a set of ARP bolts, and ready to change them. Now I am worried about an internal leak. Without replacing the gasket, is there any way to tell if there is coolant getting into the piston chamber? I thought if I checked the oil, and it was free of water, then I was in the clear. Is that true? Just hate to go through the trouble of changing the gasket if it is not necessary. Thanks.
Old 07-18-2008, 07:10 PM
Originally Posted by shatoum View Post
... is there any way to tell if there is coolant getting into the piston chamber?
After you retorque your bolts, pressurize your coolant system to about 12 pounds and see if it will hold that for 15 minutes -- if it holds, then that's a good sign your gasket is tight. You can borrow a coolant pressure tester at Autozone (or your local equivalent).
Old 07-21-2008, 07:58 AM
Looks like my coolant leak issue is mostly resolved (with your help of course - THANKS!). The coolant was running down the top of the oil pan, all the way back to the bell-housing.The leak(s) were from:
(1) the intake manifold - replacing the bolts with ARP bolts that dont stretch, and torquing them to spec fixed that
(2) the water pump gasket - tightening these bolts fixed that (I think)
Now I am wondering if I should replace the water pump bolts with a quality set. Any opinions? And is there a torque setting for these, or just "snug" is enough?
Old 07-21-2008, 10:32 AM
If it's not leaking then I would leave it alone.
Old 07-21-2008, 10:49 AM
xracerbob's Avatar
By the way, ARP and every other bolt stretches as it is supposed to in order to achieve proper clamp load in a threaded fastener joint. If you go too far, you exceed the elastic limits of the fastener and you approach the yield point. Most modern cars use head bolts that are into the yield curve of the bolt so that is why they are considered "one time use" only. It requires a sophisticated fastening tool to accurately know when you are approaching the yield point (they detect change in slope of the torque vs degrees of rotation curve during the tightening cycle).
Some very good info here:
http://www.boltscience.com/pages/tighten.htm
Old 07-21-2008, 01:59 PM
sharpe 1's Avatar
I would find the torque for the water pump bolts and torque them properly.All bolts on an engine have a torque spec. .
