Old 11-09-2008, 04:00 PM
Bob In Ct's Avatar
Question Where can I find brake fluid with some color?
During today's lunchtime discussion David mentioned that when he bleeds his brakes he uses brake fluid which has a different color than what is in the lines. In that way he knows when the fluid has been replaced.
So my question is where does one purchase DOT 3 or 4 which is something other than clear?
Old 11-09-2008, 04:09 PM
kayakjack's Avatar
Bob,
http://www.raceshopper.com/ate_brake_fluid.shtml
Jack
Old 11-09-2008, 04:30 PM
says it will mix with dot 5,i thought that dot 5 is silicon based and wouldnt mix with 3 or 4.
Old 11-09-2008, 05:31 PM
What if you were to put a little food coloring in the fluid?
" It ain't no big deal"
Old 11-09-2008, 06:06 PM
jwd's Avatar
jwd jwd is offline
You are correct, they don't mix. I don't see where they say they will. I don't agree with their comments on Dot 5. If installed correctly, there is no problem with a soft pedal. I have it in 2 cars.
Old 11-09-2008, 06:24 PM
i do too and love it,ive had no problems with a soft pedel,i think the key is to bleed the brakes slowly as not to foam it up,at least thats what i did and ive been running it for 7 years and my dad has it in his 50s truck since it first came out and hasnt had a problem.i was wondering about the food coloring myself that Tim mentioned.may work.
Old 11-09-2008, 06:30 PM
xracerbob's Avatar
There are 2 versions of the Super Blue- blue of course, and yellow so if you want to bleed the system, you can see when the new fluid appears. I would definitely not put food coloring in brake fluid.
Old 11-09-2008, 06:43 PM
i went back and looked again and it says it will mix with dot 5.1,im not sure if thats silicon,i know 5 is.yellow brake fluid hmm,reminds me when i was teen and we ran out of fluid and a guy took a pee into the master cylinder to get us home,i guess it worked i got home.stupid teens do stupid things.
Old 11-09-2008, 06:53 PM
jwd's Avatar
jwd jwd is offline
5.1 is compatible with the 3 & 4. Dot 5 isn't. The key on installing Dot 5 is DO NOT shake the bottle and pour it gently.
Old 11-09-2008, 07:06 PM
and pump the brakes slowly when bleeding
Old 11-14-2008, 02:02 PM
davids2toys's Avatar
Bob, I just found this thread, why didn't you just ask me, you have my number! Some people just like doing things the hard way
Anyway, here is the info you want.
Pegasus link
http://www.pegasusautoracing.com/gro...pID=BRAKEFLUID
They have a nice comparison chart, it is the third and fourth one down on the chart. They are
ATE Super Blue and
ATE Type 200
Hope this helps you out...Dave
PS: Check out the great WET boiling point of this stuff, and it is reasonably priced!!
Old 11-14-2008, 02:04 PM
Originally Posted by kayakjack View Post
OOOOOPS...sorry Jack, I did not see this post until after I posted my reply. My Bad!
