SUPPORT OUR SPONSOR
Old 12-09-2008, 09:53 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default Timing light hookup
Dumb question, but with the battery in the "boot", what do I hook the positive and negative leads for my timing light to? I have a single wire alternator, would it be safe to attach the positive lead to the alternator wire, and the negative (black) wire to the frame? BDR #168, neg. ground system, 351W, no accesories to speak of.
Thanks in advance
Bill
"If your work speaks for itself, don't interrupt"
Old 12-09-2008, 10:05 AM
Cobra Make, Engine: Backdraft Racing #699, Keith Craft 427 SB w/ 600+ Flywheel HP, Mass-Flo EFI
That's how I do it.
Old 12-09-2008, 10:08 AM
Clois Harlan's Avatar
That works but I like to put my positive feed on the solinoid post and then ground the black wire to my engine. I have been told that sometimes the coil will cause some intermitentant misses in your light.
Clois
"Let's roll"
"Be part of Something Good
Old 12-09-2008, 10:09 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I use jumper cables from the "boot" up to the engine for the positive wire. I hook the negative to a good ground in the engine compartment.
I suppose you could hook it to the alternator wire. Mine is very hard to get to so that's why I use the jumper cable method.
Old 12-09-2008, 10:32 AM
Silverback51's Avatar
I use a battery (4 AA batteries if I remember right) powered timing light.
Old 12-09-2008, 10:43 AM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
I hook up the positive to the solenoid & the negative to a ground on the engine, works just fine.
Juggernaut
Old 12-09-2008, 10:54 AM
Sledge's Avatar
Thank you all, good stuff once again.
I have a battery-powered light but it doesn't have the bells and whistles my new timing light has.
Bill
Old 12-09-2008, 03:14 PM
FWB's Avatar
FWB FWB is offline
i use a battery op light now but have a older sun induction light, it doesn't seem to like the msd too much i get erratic strobe. i was told thats common,
i really like the battery operated one, the lack of dangling wires is a plus, especially with headers. i used to use wire extensions to get to the battery, with rubber sleeves over the clamps so they wouldn't touch.
Fred
Old 12-09-2008, 03:54 PM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
I have an extra battery that I keep charged enough that it powers my light.
Matt
Hurricane Motorsports #1053; 427w
Old 12-09-2008, 06:57 PM
wtm442's Avatar
Beam Me Up Scottie
Grab the spark plug lead with either hand while standing in a puddle. Your eyes will blink 8 times a second (the brain only can take in info at that rate), which is ideal for any V-8 engine. You wasted good money on a timing light.
Try it with an old style magneto and we will call you Rudolph.
Inductive pick-up around plug wire #1. Pos lead of light to battery cable on firewall (starter solenoid). Neg lead grounded somewhere that is a good ground. If no flashing, try another ground.
On some inductive timing lights, they do not always work with spark plugs gapped up in the 0.045 range or higher. You may need to temporarily close the spark plug gap to 0.030 to get the light to work properly. Do not ask me how I know that.
Warren
HTML code is On
