Old 04-05-2009, 08:11 AM
Default Clutch disc air gap
I'm replacing my worn Zoom organic disc with a McLoed 11" organic street/strip. Steel flywheel was given a light clean-up cut and p'plate left alone. Worn disc was .281" thick, this one is .331". Previously ran a .040" clearance with no issue.
Would appreciate hearing your preferences on clearance before I set this one up.
Chas.
Old 04-05-2009, 08:58 AM
Hi Chas,
Recommended air gap should be .020-.035" will give plenty of disengagement on a street clutch that has marcel.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 04-05-2009, 09:40 AM
Default It depends on the pressure plate
ERA chas Chas it depends on which pressure plate you are running, 3 finger long setup I run in the .040-.060" air gap clearance. Diaphams I run in the .030-.035" range. You want a CLEAN release of the disc with the clutch pedal in. This is what I have used for the last 30+years. For the Mcleod Soft-loc thats a whole nether story. Make sure you drive easy for 300-500 miles before beating on the clutch. It needs heat cycles and not to get glazed. Try not to feather it, no riding the pedal. Breakin is as important as air gap. Rick L
Old 04-05-2009, 03:12 PM
Great advice guys-about what I figured I should shoot for, .035" to maybe .045 or 050". Should have it together by next weekend.
Chas.
