SUPPORT OUR SPONSOR
Old 05-08-2009, 07:09 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Default VDO tachometer question
I just took possession of a fairly well built roadster kit car, and the tachometer is WAAAY off--it appears to be reading at twice the actual RPM's. My speed calculator says the engine should be turning 2050 RPM's at 70 MPH, but the tach reads 4100 RPM's.
I managed to crawl under the dash and get a look at the back of the tach, hoping for a "switch" that would change the calibration for 4, 6, or 8 cylinder engines, but no such luck. What I did find was 4 lugs for wires, one for a "hot", one for the lighting on the gauge, and what looks like TWO grounding lugs.
Is it possible that this tach might read correctly if I were to switch the ground connection from the current grounding lug to the other? It's the only thing I can figure out......anyone have any ideas?
Thanks in advance for whatever help you can provide!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
HTML code is On
