Old 06-06-2009, 10:35 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default One Wire Alternator Question????
This is a picture of the back of my alternator. The lug toward the top of the picture is for the altenator positive wire and the lug toward the bottom of the picture is for a grounding wire, Correct?????????
Boy, I'll be glad when this wiring is over and maybe then I'll quit SECOND GUESSING myself:LOL :
Old 06-07-2009, 05:43 AM
Tony Radford's Avatar
Earl, the top insolated stud is definitely for the battery wire. If the bottom lug shows continuity to the alternator housing, then it's a ground terminal. I just replaced my one-wire alternator yesterday. Mine doesn't use a ground wire. A "one-wire" is typically just that.
Old 06-07-2009, 06:32 AM
joyridin''s Avatar
Hook up a wire to the lug with the red plastic and you are done. It is already grounded through the housing with your mounting brackets. No need for any other wires.
Old 06-07-2009, 07:08 AM
undy's Avatar
Some installations use rubber suspended/encapsulated bushings for mounting the alternator to reduce NHV. I applications like that the bottom bolt offers another option for proper grounding.
Dave
Too many toys?? never!
Old 06-07-2009, 08:50 AM
Ouch Ouch Hot Sand
Ahhhhhhhhhhhhhh, thanks for the responses, makes sense now. I went ahead and ran one of those 4 gage pre assembled negative battery type cables from the frame to the lower lug. Like my wife says I tend to "OVER" engineer or "OVERKILL" things
Old 06-07-2009, 01:42 PM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
http://www.madelectrical.com/electri...hreewire.shtml
Here's an article my friend found while researching alternators for his Camaro. We ended up using a Powermaster, wired as a threewire.
