Old 10-10-2009, 10:09 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Pip & spout
Somebody PLEASEEEEEEEEEEEEEEEEEEEE explain PIP & SPOUT to me in simple terms I can understand......including which one sends out a signal to the computer and for what purposes.....Thanks, Earl
Safe Flyin, errrrr Drivin, Earl
Old 10-10-2009, 12:45 PM
http://www.wrenchead.ca/HTML%20Prese...der/sld057.htm
Old 10-10-2009, 01:08 PM
And if you want to download technical manuals, tune-up articles, or the software itself, this is my favorite spot for it: http://www.fordfuelinjection.com/
Old 10-10-2009, 06:38 PM
Ouch Ouch Hot Sand
Two great sites but both WAY over my head.....LOL.....what I thought was this;
the computer controls the distributor........
what I learned was this;
the distributor controls the computer.........
what I need to know is this;
is it the PIP or the SPOUT location coming out of the distributor that controls the computer???
I am trying to get my engine running with an aftermarket computer (Microtech MT-10) and get spark until I add the computer into the equation........so......whatever tells the computer to work is not doing its job...........
Old 10-10-2009, 06:42 PM
I read an article just last week on how to diagnose an intermittent no-spark condition with PIP and SPOUT. Let me see if I can find it.
Old 10-10-2009, 06:51 PM
Default Found It...
Take a look at this and see if it helps you.
http://www.asashop.org/autoinc/dec2002/techtotech.htm
Old 10-19-2009, 06:29 PM
SPOUT is for disabling computer timing adjustment to the TFI module (unhook to set timing), PIP is the tach signal. The TFI can work on it's own without the computer (which is what the SPOUT actually does), you loose advance but it'll idle.
GM chose to label the tach terminal "Tach" for some strange reason...
Old 10-19-2009, 07:32 PM
Ouch Ouch Hot Sand
Welllllllllllllllllll, i now have a VERY GOOD working knowledge of PIP and SPOUT but STILLLLLLLLLLLLLL INJUN NO RUNNIE!!!!!!!!!!! I'm getting veryyyyyyyyyyyy FRUSTRATED at this time, but I WILL NOT GIVE UPPPPPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!!!!!!!!!
