Old 04-12-2010, 06:55 PM
FUNFER2's Avatar
Default Best Trans. Fork ? FE (Hyd. bearing) Quick Time bell.
I just got a very nice SFI rated "Quick Time" bellhousing. Who makes the best fork and adjuster ?
Mines old & bent a little and want to replace it.
I have a hydraulic throw out bearing on a FE.
http://www.quicktimeinc.com/products.html
Old 04-12-2010, 07:20 PM
David Kirkham's Avatar
Original Shelby Owner
We make the complete set up with a billet fork. $400.
What kind of transmission are you running?
Old 04-12-2010, 08:37 PM
FUNFER2's Avatar
lol,.... should have known.
The new side oiler and the Tremec 600.
Aluminum flywheel and McLeod RST Twin Disc from Brent at B2 Motorsports.
I just looked and see he also has a fork.
What all is included, and can you post photo's either on this thread or send me a email. I would appreciate it.
cobrakev@galaxycable.net
Old 04-12-2010, 09:06 PM
You can see more info on the Kirkham setup starting in about post #66 here:
http://www.clubcobra.com/forums/show...row#post755374
That is for the lakewood, but basically the same for the QT.
You get the arm, pivot, slave cylinder and TO bearing and mounting braket.
Old 04-12-2010, 09:22 PM
I just put a Mcleod hydraulic TO bearing in the last set up I assembled. They have a contained piston now so they can't overstroke/leak/come apart. It needed a different length piston from the one it came with but is a very compact and tidy set up all done. I like these. http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
http://www.actoncustom.com/
Old 04-13-2010, 04:44 AM
Hi FUNFER2,
I have the same fork setup as a bolt-on that is pictured above. The Kirkhams purchased 3 of them several years ago with the story of buying more. I see their part is almost exactly the same as mine.......
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
Old 04-13-2010, 05:29 AM
FUNFER2's Avatar
Forgive me for my ignorance. I assume mine is a hydraulic as I have three master cylinders, two for the brakes, one for the clutch. I don't have the car here so I can't look at it but, it has nothing like shown. How do I find out whether it's hydro or not ? (I'm sure it is but, I'm still asleep)
What are the pro's & con's of a hydro clutch ?
Will I need one for the twin dick clutch ?
A fellow LSC cobra owner may have bought yours Mike, and it won't fit, it hits the frame. I'll make sure,...... this is what he has and get back to you.
$400 at Summit, wow.
For the same money, I'm sure the Kirkham & Mikes is higher quality !
Mike- This is what the other LSC has and it hits the frame. I can only assume the other makes will have the same problem ?
Old 05-24-2010, 08:52 PM
GT350Mike's Avatar
Cobra Make, Engine: CSX6363
FYI - I have a McLeod hydro setup that I've been running in my Mustang for about 10 years and I don't recommend it. It's a PITA to bleed and God forbid when it starts leaking (and it will) because you will have to pay $$$ for several O-rings. Even with the high price for the parts, I received an incomplete shipment.....I was missing two O-rings. On the positive side of the McLeod setup, I enjoy the super light pedal pressure needed to shift!
Old 06-01-2010, 11:10 AM
FUNFER2's Avatar
I'll call Mike and David to chat about this, hitting the frame situation. I don't know what else can be done. Like I mentioned, a friend also has a LSC so, I'll see if he wants to get involved here.
(I know I have a Hydro bearing, and don't see why I asked)
Old 06-01-2010, 11:24 AM
Cobra Make, Engine: LoneStar 427 SC, "Red Venom", 351W B/S 400 HP, TKO 600 .64 OD
Here's my set-up on my LSC, FWIW.
It's a home-made bracket and a Ford clutch fork.
Randy
Old 06-01-2010, 11:53 AM
FUNFER2's Avatar
That looks great Indy !
Where did you get the specific # Wilwood cylinder ?
Is that a Quick Time bellhousing ?
Is this the one you have ?
http://wilwood.carshopinc.com/produc...57713/260-1333
And part # ?
Description of WILWOOD 260-1333
PART#WIL260-1333
CLUTCH SLAVE CYLINDER
Price-$65.95
Any problems ?
How do you like it ?
I'll send you a PM/email.
Thanks.
Old 06-02-2010, 03:55 AM
Sent you a PM back.
I don't have a part number. It is the slave that is provided by LSC in their current kits. Call Brian at LSC and I'm sure he can provide the right number.
That is a Quicktime bellhousing. Part number is 6060 for a 351W, which is the engine I'm running. Since you are using a 428, you will have less room than me. Still, if you fab a bracket, you can make it work.
I'm still building so I haven't tested my setup yet. I don't anticipate any problem though. When bleeding, the bleeder nipple will be on top so I can get all the air out of the cylinder.
Randy
Old 06-02-2010, 04:29 AM
FUNFER2's Avatar
Hey Randy, good news. I'll call Brian today.
Too bad he doesn't have a parts page with photo's and information.
I'll rattle his cage a bit. lol
Old 06-02-2010, 10:25 AM
I got one of those slave cylinders from Brent at B2. You mention a hydraulic throwout bearing. If you have one of those you don't need a fork. They are a very compact little internal unit with no frame clearance issues. If you use an external slave cylinder a stock clutch fork has clearance issues on the frame. They can be cut off on the end for clearance, have a new end put on the fork with a heim or replace the fork with something like Fortes.
Old 06-02-2010, 10:32 AM
FUNFER2's Avatar
mickmate- can you post a photo ?
Old 06-02-2010, 11:08 AM
Sure, what of? Note the Wilwood slave shown is a pull cylinder not a conventional push. They need a fork with the pivot point on the other side of the throwout bearing.
Old 06-02-2010, 11:33 AM
Well actually, you can install it either way depending upon the bellhousing. If the pivot ball was on the drivers side, I would install the cylinder pointing towards the back. Works either way.
Also, there's no frame clearance issues on the Lonestar either way. I think there is a mix of hydraulic bearings and slave cylinder set-ups. Lots of pros and cons either way. You can search the archives for the previous discussions on the topic. Since LSC went with the longer throw hydraulic cylinder, there have been fewer problems.
Randy
Old 06-03-2010, 10:38 AM
lovehamr's Avatar
Stolen Avitar
Kevin, if you already have a hyd. T/O bearing why would you want to switch to a fork and slave setup?
Old 06-03-2010, 05:00 PM
Here's the clutch slave I've been running for the last 4 years. It bolts to the front side of My Pond block's left rear ear. It's listed for a Y Block or FE powered 1957 through 1965 Ford F100. It's 23 bucks from Rock Auto. It clears everything on my Lone Star. It starting leaking a bit from the piston seal so I just bought a new one.
Old 06-03-2010, 09:22 PM
lovehamr's Avatar
Stolen Avitar
Thanks Dave, that's a find!!
