Old 08-24-2010, 02:58 PM
Neutral
Question ford fe engine cradles
does any know if they make a fe engine cradle that will let you bolt the flywheel on and bellhousing? if so who sells them.
Old 08-24-2010, 04:00 PM
xlr8or's Avatar
All you need two flat pieces of 1/4" steel and some 2X2 steel tubing. Drill and bolt the flat plate to the motor mounts then weld a piece of 2X2 going straight down mate it to another 2X2 going front to back. Basically an upside down T shape with an angled plate on top.
I believe Kieth Craft or Gessford makes/sells them.
Old 08-24-2010, 04:03 PM
Fordzilla's Avatar
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Send this guy an email on this site:
http://www.stumpysfabworks.zoomshare.com/
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
Old 08-24-2010, 04:07 PM
Fordzilla's Avatar
He's also got one listed on feebay:
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Mick
Old 08-25-2010, 05:45 AM
He also makes a slightly wider version for engines with a wide oil pan. I needed the wider one with my Aviaid pan.
I put wheels on my cradle so I could roll it around.
Rodger
Old 08-25-2010, 08:01 AM
Thumbs up
Same thing here, it's a nice stand... (get the wide one if you have a t-pan)
The only thing cooler would be one with interchangable heads for different engines.
