3Likes
01-31-2013, 05:13 PM
Pre-oiler question
I'm trying to decide whether or not to use a pre-oiler for my ERA Cobra. The benefits to me seem pretty obvious (and Brent, who is building my engine agrees).
So my questions are:
(1) Any real reason *not* to do this, aside from the cost?
(2) For people that have done this, what are the pros/cons? Happy you did it?
(3) Do you need a remote oil location kit (expensive) for one of these, or is there a good way to do it without?
(4) What size is best for a 427 SO, stroked to 482?
(5) What is the best location?
(6) Is Accusump the way to go?
Thanks!
01-31-2013, 07:09 PM
ME
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
1. None, do it!
2. I like 12 qts. better than 5 or 8 depending on pan type. Also 20 to 50 psi @ start up, depending on oil pump pressure at prior shut down. It's just the ticket, when your FE has been sitting awhile.
3. My accumulator is piped to a seperate location out of the engine bay. The total piping/hoses provide a extra 1qt. total; for the system.
4. I have a Iron block/head (C5AE-H) HM built FE 427 sideoiler, pushing the old double nickel. 500+HP & 500+TQ. I'm sure your chosen system will serve your stroked 482, just as well as mine does for me. If properly installed.
5. My accumulator is located under the passenger (under carrage) seat. It works well on the street & the track. As I don't do much (knock on wood!) off roading.
6. I use a Morroso 3 qt. accumulator, with a 8.5 qt. baffled pan w/windage tray. The piping also adds 1 qt. This gives me a total of 12+ qts. at all times. Even when I'm driving hard into a corner, or pushing 7 grand. But Im sure whatever type accumulator you chose will serve you well.
I hope this helps! By the way great choice on your ride  Not that I'm
Biased or anything
01-31-2013, 07:33 PM
Originally Posted by Silversmith
...pushing 7 grand.
Pushing 7 grand what??? Pianos?:
An iron 427 with iron heads making 500 / 500??
All done at 5200.
Twelve quarts? Who told you you need that? You endurance race?
H & M were great engine builders, not magicians.
Lippy, watch from whom you take advice.
01-31-2013, 08:22 PM
1. None, do it!
Biased or anything
Thanks, that's really helpful. Could you help me understand how you piped it from the engine? Did you tap off the remote oil kit, or use the oil cooler piping?
01-31-2013, 08:35 PM
If the sole purpose is to pressurize your system because your car sits a long time between start-ups, then I don't think you need it.
01-31-2013, 07:40 PM
CO
OEM engines don't use a pre-oiler, and they last well over 100K miles on routine maintenance alone. Personally, I don't see the need for one.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
01-31-2013, 08:57 PM
ME
Chas, I'm sure you have more knowlage about FE's than I. I was stating a opinon about accumulators. The engine I have pulls very strong approching 7000 rpm. While it's true my AC dosen't pull like CSX 3116 that I grew up in did; even though both AC's have & had the same engine type & builder. CSX 3116 did have two 715 holley dbl. pumpers, a different cam & 12.5:1 compression to my single dbl. pumper, a like cam & less compression. Also, CSX 3116 did weigh almost 500lbs less than my era. But I assure you that my sideoiler will pull very strong @ 7000rpm. In fact, if you wish to come to Maine I will be happy to show you. Once the snow melts that is.  Bring your ride, we'll take a romp up on the Kangamangus Hwy. in the White mountains. Then romp down to the coast & pig out on Lobsta's. As to my accumulator & my recomendation? I feel extremely secure with 12+ qts. I have heard it said, when it come to real power "there is no replacement for cubic inches." Well, I feel the same way about oil & oil pressure when high Hp is involved, more is better!. Thats my opinon, & I'm sticking with it.  By the way, Holmon Moody is still around, and they were/are magicians!
01-31-2013, 10:07 PM
ME
Lippy, The accumulator, the oil cooler, engine, piping etc.. It's all one system. Think of your oil flow moving like electrons in a electrical series circuit; from negitive to postive. Hot oil moves out of the engine through the cooler, through the accumulator back to the engine. When the engine is shut down the accumulator stores the oil @ pressure until called for. When your ready to restart, supply voltage to the accumulator, open the valve, build pressure & start engine. the engine never runs w/out oil pressure. The accumulator can be mounted anywhere, in the engine bay or out. I pefer mine out. For me, I feel it keeps the oil cooler during hot driving conditions. A friend of mine who races AC's alot, has his accumulator sitting in the place of the passenger seat!  A BB engine in a AC produces alot of heat!  Cooler oil is better oil IMO. The accumulator system you investagate/buy. Will/should have quality instructions on the instillation procedure. Plus, I can think of no better engine builder (except mabe HM) than Brent. To help you sort through the accumulator choices, & best location for installation. Good Luck M8
01-31-2013, 10:58 PM
Thanks again! My question really is: where did you plumb the accumulator system into the existing engines oil system? On the oil cooler, on a remote filter block, or somewhere else? If I do this I'm trying to figure out if I need to get the remote oil location kit from ERA.
02-01-2013, 05:47 AM
I think you just want an Accusump.  That's ok, there's nothing wrong with that. Just remember, a lot of us have cars, and have had them over the years, that only get started every few months or so, and they suffer no ill effects. My Cobra sits, untouched, from Thanksgiving to Easter. Then I just crank it a little bit until I see the oil gauge needle move, turn on the ignition, and fire her up. But, if you want an Accusump, then put in an Accusump. Here's how you might do it in an ERA:
02-01-2013, 06:47 AM
tx
Here is the Accusump installation instructions. That will help you figure out the plumbing. If you want to keep the filter on the block, there is a sandwich adaptor with a thermostat that mounts to the block.
Canton Racing Products - Accusump Tech
01-31-2013, 11:00 PM
That's a good point, but I use my daily driver every day, and realistically there will be times my Cobra may sit for a month between drives.
02-04-2013, 05:46 AM
Me
Gave this a lot of thought,a very good idea but just a little overkill.Think about antique motors that were splash fed (no oil pump and of course no oil filter)and how long they lasted with babbet bearings no less.My fix was use synthetic oil, it resists heat a lot better they claim it stays in place better.
02-04-2013, 06:00 AM
KY
I don't know of many antique motors with 10:5 compression, 600 hp, roller lifters with needle bearings, etc. Those old motors would run with strips of leather behind the bearings....hahaha.
02-05-2013, 05:06 AM
Me
Your right blykins was trying to make a point.Think then about compression ignition diesel engines that are started every day like their counterpart gas engines and how long these motors last.
One example Amsoil advertizes is a trucker with bypass filtering went 409,000 miles on one oil change,course he had his oil analyzed periodically.
I do believe in the Accusump or something similiar for racing and for those that feel the need on their pride and joys.
As many engines as I have built or rebuilt and seen the condition some of them were in while tearing them down know for a fact what works and what is overkill especially on the street.Race motors presents another whole ball of wax.
02-05-2013, 05:56 AM
KY
I would imagine that a big diesel engine spends 90% of its time running anyway, so start-up wear is greatly decreased. These guys will put 400k miles on an engine in a couple of years, so it's a totally different application.
Regardless, if I were to spend that much money on a car, and that much money on an engine, the $400 bucks or so to eliminate any chance of wear just seems beneficial to me.
I see the resounding theme of that oil pressure builds up in a few seconds or so, but what happens in that few seconds before the oil gets there? Kinda hard to say and I'm sure it varies from engine to engine.
Cheap insurance.
I really don't know what would be the "negative" of buying a pre-oiler....cost? Fitment? The aggravation of activating it before you fire the motor? If it were offered for free, would you all still pass on it? Or would you say, "Yeah, give it to me."
From time to time I find myself in discussions on various forums about engine building practices. I have expressed concern on different times about using Plastigage to build an engine, only to find myself in a heated argument about criticizing others' engine building practices. Even got myself kicked off of another forum for sticking to my opinion....hahaha
Regardless, the words I kept hearing were: "If I were to buy an engine from you Brent, I would expect you to check the clearances with a mic and bore mic and map them out. However, I can't afford to buy a mic, so I use Plastigage."
It's the same thing here....I'm offering my opinion, but if you guys were to buy an assembled car/engine package from me (if I did that sort of thing), there would not be much said about it if I stuck an Accusump in there.  So where is the line drawn?
02-01-2013, 09:25 AM
Thanks!
No reason not to, Accusump is a good way to go and a popular choice here, Moroso also good and there are others you can google. A 1 QRT system will work just fine for pre-oiling, if you want some "reserve" for maintaining good oil flow through hard cornering then get the 3 QRT system. Go to the Accusump website and read recommended accumulator size for your intended application.
02-01-2013, 09:39 AM
Ill
KISS
keep it simple s--------------------------------
Remember that for every corner that the accusump keeps your oil pressure up, It also takes away while it refills down that straight after the corner while you are running it to 7000 between the gears----
Oh, bet nobody ever noticed their oil pressure while turning 7000 -----------
02-01-2013, 10:09 AM
Originally Posted by Jerry Clayton
KISS
Definitely apply KISS, and on everything you do with these machines. I've always been an advocate of using the highest volume oil pan you can fit, when shock compression puts you in contact with asphalt backoff a little
02-01-2013, 11:33 AM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
I thought the OP's question was about pre-lubrication as distinct from accumulators and systems designed to prevent oil starvation. Such simple prelubers exist and we used to use them on turbo motors before the advent of water cooled bearings. We ran them till we heard pressure bog the pump on start up and ran them on a timer at shut down. Today it is focused on preventing a dry start. The reservoir is your existing oil pan. Simple and effective in my experience.
Ciao
