Go Back   Club Cobra > Cobra Talk Areas > Coupe Talk
Old 03-25-2026, 10:14 AM
Default Superformance / Shelby Coupe - need new drive shaft
I have a Shelby Coupé CSC 9131. Now i need to now what type of drive shaft is in. The diff. is from a Camaro 2010. I think that the drive shaft is also from a camaro. The joints on mine are worn out.
Thx Axel
Old 03-25-2026, 02:31 PM
twobjshelbys's Avatar
CSC or CSX? The 9000 series coupes are Shelby cars. But they don't use Chevy bits... How old is it? Must be something like 20 in order to make it into Europe.
Tony
CSX4005LA
Old 03-26-2026, 11:36 AM
nkb's Avatar
nkb nkb is offline
Cobra Make, Engine: Alloy Shelby CSX 8057/Kirkham 1010, 289 Vintage Lykins Build
The Shelby continuation rollers are delivered without a driveshaft. The driveshafts are supplied and installed by the owner/installer. So, there will be no "standard" driveshaft spec. The driveshaft is also dependent on the transmission length dimension, also not delivered with the roller.
You will need to measure the current length and the Spicer joint model numbers and order a custom driveshaft. The required measurements needed for the fabrication are as specified by the vendors such as Denny's or Inland Empire Driveline. They can tell you what to measure and then create the correct fitting driveshaft.
Old 03-26-2026, 11:43 AM
Senile Club Cobra Member
The drive shaft is not from a Camaro but was custom made to specs provided by the powertrain installer. Take you shaft to a decent driveshaft shop and they can replace/rebuild it. The lower cost solution is the better option here.
rick@autoventureusa.net
Old 04-05-2026, 02:33 AM
I meen the drive shaft from the diff to the wheels.
And yes, the CSX Coupe has an Camaro Diff. I realy now this, i have change the ratio.
Old 04-05-2026, 04:36 AM
mrmustang's Avatar
Gold Star Contributor
Do you have the Superformance Owners Manual?
https://secondstrike.com/Technical/C...nersManual.pdf
Your actual differential is not a Camaro item per se as the center section was used in multiple GM products over the years, but it is a "Dana 44" (Dana-BTR) and that is what you need to state when speaking about it. Although, SPF also for a brief time used a "ZF" differential so you'll need to check the following url to see which one you actually have:
https://superformance.org/scof_tech_...ferential.html
A loss in translation was apparent here, you need a "rear axle", or "half shaft", the question now is, do you need a left or right axle assembly?
In addition, SCOF has a list of other tech features, but you must join to access them.
https://superformance.org/scof_tech_feature/
Bill S.
