Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > AC MKIV
Old 05-13-2026, 04:01 PM
Cobra Make, Engine: Autokraft, Ford HO 302
Default New Steering Wheel, & BOSS for 6x70MM wheel
I thought I had posted this, but I must have made in error so here goes again. Pulled my OEM Moto Lita 13" black leather wheel, and discovered of course my 9 hole Moto-Lita boss and 36 spline steering column shaft. Pictures are below. I wish to use a 6 hole wooden wheel, either a Corso Feroce which I use in my Ford Mustangs, or an original 6 hole Moto Lita example. They are Italian made, 15" and look great IMHO. OR, I could use an adapter on the pictured steering wheel boss, but that adds about an 1" of depth to the steering wheel, and gets a little busier. I checked with Moto Lita, and their 6 hole wheels are 6x62MM PCD, which is kind of proprietary to Moto Lita. They can make me a 6xx62MM boss, and sell me their 6x62MM wheel along with a center cap. Frightfully expensive, but well done. Most 6 holes like the Corso Feroce are 6x70mm PCD, and considerably less expensive. If I go with a 15" Corso wheel, then i will need a new 6x70mm Boss and then the wheel and center cap of course. Anyone use a 6x70mm boss that will fit this SD1 Rover (I am assuming?) column? The boss needs to be about 2" tall to match the OEM boss I removed. Or would you simply use an 9 to 6 hole adapter on top of my existing boss? Thanks in advance for your help and suggestions. Cheers from Dallas, Brad.
Old 05-14-2026, 10:55 PM
Exclamation Note:
Moto Lita is a British brand, not Italian, even though it sounds like it should be!
You have an early style hub. The later hubs are different and have an asymmetrical fastener pattern. Depending on what you are replicating, you may want to consider your options. The original Cobras had 16" diameter wood steering wheels...
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 06-03-2026, 01:24 PM
Yes sir Paul, my bad! Moto Lita is indeed British, and I know better...thank you again.
