Old 07-22-2004, 01:52 PM
S_Beaudry's Avatar
Cobra Make, Engine: (building) - Hunter #74 w/ 302 small block (320hp under the hood). . . how many wires are there in a wiring harness?
Send a message via AIM to S_Beaudry
Default 460ci . . . . Can I use a T-5?
I've heard as many yeses and no on this one so here we go . . .
I got a simple stock 460ci and want to use a T-5 with it.
Some say it will not match up, and some say it would work fine.
So, before I drop the $$$ on a tranny, any advice for me?
Please . . . .
I'm not busy because I did it right the third time . . .I think!
Old 07-22-2004, 02:26 PM
Cobra Make, Engine: B+B 351w #112
My first t-5 lasted 760 miles behind a 351w. Spend the money and buy a tremec. Jim
Old 07-22-2004, 02:28 PM
MJN MJN is offline
Cobra Make, Engine: FFR2100X (Mk1) - Whipple Blown 331
A 460 will turn a stock T5 gear set into a lot of small pieces. G-Force does a high torque gear set that might work but that would put your investment in the $ range of a Tremec.
Old 07-23-2004, 05:43 PM
Don DePontee's Avatar
Cobra Make, Engine: FFR-4000 under construction
Send a message via AIM to Don DePontee
Go for the new Tremec 600.
Don
Old 07-23-2004, 07:43 PM
Cobra Make, Engine: Shell Valley- smallblock grenade w/ the pin pulled
Default Re: 460ci . . . . Can I use a T-5?
Originally posted by S_Beaudry
any advice for me?
DON'T DO IT!
"If you're not racin' it, you're wastin' it!"-Me
Old 07-28-2004, 12:57 AM
Cobrabreeze's Avatar
Cobra Make, Engine: none at this time
The TTC 4615, 4617, 5008 or 5021 are all very good options; but not the T5!
Fred Sanderson
Dark Horse Performance Inc
425-227-7778 Phone
425-271-9111 Fax
Old 07-28-2004, 03:38 AM
Cobra Make, Engine: FFR2479K, 351W yellow/black stripes
Steve,
C'mon buddy. You're going to drop that tank into the car and try to get away with the T5? I ain't a mechanic, but sumpin' sure don't seem right about that... Besides, what happened to going with the small block?
I think a mild build up 351W is about as far as you'd want to go with the T5. A 460 would eat it for lunch.
Get serious about driving your Cobra and go with the 351W.
www.midatlanticcobras.com
No, it ain't "real", but it's real fast....
Some people choose to rattle their windows with stereos and speakers... I choose to rattle windows with my right foot.
Old 07-29-2004, 07:10 PM
A T5 is only rated between 235 up to 310 lb/ft of maximum torque, depending on the year it was made. Even a mild 460 would chew it up in no time at all.
Just get the Tremec Ford TKO 600, it will pay for it's self in not having to rebuild it every week or two.
The Ford TKO 600 is torque rated at 600ft/lbs. 26 spline input shaft with a 31 spline output shaft. Comes in two standard over drive configurations 1) 2.87 first gear .82od and 2) 2.87 first gear with .64od. Standard shift location is the rear "Mustang" shift point. Mid and front shift kits available. Main case bolt pattern remains the "toploader" pattern.
Hope this helps.
Old 09-05-2009, 10:39 AM
mdross1's Avatar
Please . . . .
Looks like you have the answer you were looking for.That 460 will get you down the highway just the way you want to go.Make sure your brakes are up to the task.These big inch motors will get you there a lot faster than you realize.Good Luck
Old 09-05-2009, 11:22 AM
Go with the TKO 500/600. The T5 won't last long.
I'm offering a special right now...
I can also supply all clutch components/bellhousings/flywheels, etc. that you will need.
