Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
June 2024
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-01-2006, 11:12 AM
walt347's Avatar
Cobra Make, Engine: FFR, 347stroker, 48IDA and '66 Mustang GT convertible
Default Leaner top end for my 48IDA Webers
I run the following setup on my 347 Ford stroker:
Idle jets 55
Idle jet holder 60
Air corrector jet 210
Emulsion tube F5
Main jet 150
This setup runs quite well - no sneezing, good torque. However, at top end (4000 - 6000 rpm) it runs extremly rich.
I want to have a leaner top end. What do the Weber specialists recommend ?
Thanks a lot for your support.
Walter
Old 07-01-2006, 01:13 PM
Full Throttle Al's Avatar
Cobra Make, Engine: CSX4083, NOS 427 SOHC, serial number 589. Dyno'd in 1967 at 629HP with single 4v 560 Holley. Now with 4 Webers.
Go down 2-3 sizes on your air correcter jets and re-check, may need to go even smaller.
Alan Sorkey
Shreveport, LA
Old 07-01-2006, 02:08 PM
Alan,
Are you sure? With a Solex carb, you use a larger air correction jet to lean out the upper end. This page corroborates the effect with Webers.
Old 07-01-2006, 02:29 PM
You are correct, I meant to go with a larger number air corrector to lean mixture at top end.
