Old 07-06-2008, 10:23 PM
Cobra Make, Engine: B&B, 428 FE, toploader
Default Fuel pump recommendation
I currently have a blue holley electric fuel pump part#12-802-1 and am thinking about replacing it with the Holley hp series part #hly-12-125 because it is supposed to be better and quietier. Has anyone had experience or thoughts about the hp pump? Thanks, Chas
Old 07-06-2008, 10:24 PM
Sorry about the double post but my computer sent me to lala land and said it didn't go the first time.
Old 07-07-2008, 04:17 AM
Cobra Make, Engine: ERA, Ford 428 SCJ
Unless you are having fuel delivery issues, I wouldn't change.
Old 07-07-2008, 05:24 AM
55312's Avatar
Cobra Make, Engine: E-M 427 Top Oiler stroked to 482 by KC, Stage 2 heads, a Quikfuel and Voila, 640 hp
I did this exact swap when my blue one died. So far so good after about a year. It's much quieter but it is a little longer so make sure you have room if you go with it.
Tim
At first, nothing happened. Then after a few seconds, nothing continued to happen.
Douglas Adams - Hitchhiker's guide to the Galaxy
Old 07-07-2008, 05:35 AM
jams's Avatar
Cobra Make, Engine: B & B
I finally installed a mechanical pump and I am so happy. No more pump noise! I tried 2 different pumps a Holly and a carter both boasting Quiet and they were anything but.
An in the tank pump is quiet, can you make that happen?
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 07-08-2008, 08:34 PM
Thanks everybody for your replies.
Traveller-I am not having problems but I am trying get it quieter
Tim-glad to hear you had a good experience because that convinces me to go that way
Jams-I am looking for an easy fix and the HP pump seems good. I have the standard B&B tank and don't know anything about putting an in tank pump from scratch.
Thanks again, Chas
Old 07-09-2008, 03:27 AM
Roscoe's Avatar
I've been through Holley blacks and blues and finally threw them all out and went with an Aeromotive pump and regulator. Never looked back.
Roscoe
Roscoe
Old 07-09-2008, 06:26 AM
On my previous Unique, the electric fuel pump was very loud and it was mounted to the chassis - without a rubber pad between the pump and the chassis. Installing the pad / damper - quieted the pump noise significantly. Rick
Old 07-09-2008, 06:58 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
I dont think much about fuel pumps since I ditched my Holley blue for a mechanical. A local builder, Joe Lapine, once told me he would never put an external electric fuel pump in a street rod, race only. I think he was concerned with safety and reliability for the street. If the engine stops, the fuel stops, no manual or pressure switches required. I took his advice and switched to mechanical and it has been a plus. No noise, one less thing to debug.
Aeromotive pumps are supposed to be good, and Barry Grant as well.
If I can see you, I'm too close
Old 07-09-2008, 07:49 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Just installed two Holley red pumps on the GT40. They're mounted to the rear bulkhead, which is directly behind the seats but in the engine compartmet. I used rubber grommets for noise isolation, limiting noise to a reassuring purr. Like to hear the pumps. However, if they are mounted directly to the body . . . lots of noise.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
