Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Old 09-01-2009, 09:03 PM
Default sway bar
has anybody had any problems with rear sway bars on 4000's? i had a noise as if something was loose. mostly when going foreward to reverse. reverse to foreward. or letting off the gas going up my driveway. i chased the "clunk" to the upper brackets securing it to the frame. there is no bushings, so if i tighten the brackets the sway bar will not twist. if i loosen them i get a clunk.
Old 09-02-2009, 03:40 AM
Funny that they don't have a bushing. If no one has any insight here check http://www.csxinfo.net
http://www.actoncustom.com/
Old 09-02-2009, 05:19 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
You may have the brackets installed incorrectly. They are offset to one side and if one half is on backwards, they will bind up.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 09-02-2009, 05:58 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Hi
I had the same problem on a build, (the blocks need to be tight). I had to take both blocks off the car and assemble them on the bench and ream them to fit the sway bar. When I assembled them back on the car I put some grease where the bar contacts the blocks, no more problems. If your bar is powder coated it could be the thickness of the coating causing the problem, if so you could try and remove the powder coating right where it contacts the blocks.
