11-24-2009, 10:08 AM
Cobra Make, Engine: SPF 2168, 418, TKO 600
351W intake gasket recomendations??
I have a 351W with Victor Jr. heads and intake manifold. The engine was rebuilt last year and I'm noticing a puddle of oil on the back of the block every time a take the car out for a short drive.
The engine builder used the cork seal for the back of the intake manifold and it hasn't moved but it is clearly leaking.
I'm looking for recommendations for:
1. What brand intake gaskets to use (part number if possible)?
2. Should I use cork or a bead of silicone?
I appreciate any suggestions you have. I can't stand oil leaks.
Dan
11-24-2009, 10:48 AM
Dan,
Send Steve (Panavia) a PM or email. The Fel-Pro gasket on my engine failed and the Mustang Ranch replaced it with an Edelbrock gasket.
Doug
11-24-2009, 10:53 AM
Originally Posted by Got the Bug
Dan,
Doug, Did your Fel-Pro gasket fail on the ends of the rear of the intake or on the side where the ports are?
I will give Steve a call as well.
Dan
11-24-2009, 11:25 AM
Cobra Make, Engine: Kirkham FIA
Dan,
I had Felpro gaskets fail at the intake runners on cylinders 2 and 3 on my
351w. After confirming the manifold was not warped, I changed out the gaskets with Cometic and used a high temp sealent on both sides from Toyota (part # 00295-00103). Cross torque the bolts on installation (24 lbs.), run the engine, let it cool over night and retorque. No problems since. I now check the torque on the intake bolts every couple of months.
anicholas
KMP 517
11-24-2009, 11:42 AM
The best gaskets I've seen for Windsor is the ford racing
part #9349 steel reinforsed intake gaskets
I'm going off memory on the part number
check on the ford racing web site to make sure
11-24-2009, 12:15 PM
I've been using Felpro gaskets for 40 years and have never had a failure but I don't remember ever seeing any black intake gaskets. They were always blue. I never use the end gaskets on intakes. Clean everything with acetone and use a bead of silicone.
11-24-2009, 11:20 AM
Dan,
Here's a thread with a picture. The front and back on the driver's side failed completely.
Mustang ranch- roush authorized dealer
Doug
11-24-2009, 12:19 PM
I'm currently using the Edlbrock gaskets (EDL 7220), but mine is failing in a different location. Oil is leaking in the rear between the manifold and the block. Not the between the intake and the heads.
Do you know if you Mustang Ranch used cork, rubber, or a silicone bead for the rear of the manifold to the block?
Dan
11-24-2009, 01:58 PM
Dan
I just went out and took a look a the receipt and the 7220 is the gasket that the mustang ranch used. Steve can provide more details about why he uses that gasket and the pros and cons of other gaskets.
It's my understanding that there was a bad batch of black Fel-Pro gaskets that failed over time.
Doug
11-24-2009, 03:24 PM
Greetings ! == It's gasket time !
OK, so a few years ago we had issues with the Fel-pro black gaskets failing in the face of modern gasoline and coolant.
We then very shortly went to the Edelbrock 7xxx series of gaskets and haven't looked back. (depending on setup)
-- For front and rear seals we use a healthy bead of "Right-Stuff" which is an air-propellant silicone. We also will do a small bead around the water jackets, and leave the intakes dry.
The most important things here are cleanliness and dry surfaces ; cleaned with brake-kleen, or isoprophyl alcohol before you start, free of all oil gasket materiel / and after you put it together torque the intake down 19lbs max for AL intake , 24 Lbs Iron intake.
KEY: Let the whole thing dry overnight 12 hours+ , prior to coolant and any firing up.
Hope this helps.!!!!
