| 29 |
01-02-2010, 09:18 AM
I've had the best luck in torqueing head bolts when I wait for the ambient temp to hit <32 degs, then torque away. Give it a try
01-02-2010, 09:29 AM
OR
Where did I puy that freon spray...
ERA FIA 2088
01-04-2010, 12:29 AM
Sounds like you are on the right pathway , could just be a gasket.
if it happens again , then i would say you have a potato chipped shapped cylinder surface or head surface.
01-04-2010, 06:31 AM
OR
Thanks guys! I got her all buttoned back up yesterday morning. We'll see what happens...
ERA FIA 2088
01-04-2010, 09:50 AM
Make sure it's burped well!
Good luck!!
01-04-2010, 09:56 AM
OK
[QUOTE
maybe a warm up and a retorque could have preventad this???????[/quote]
This is key especially when you are running Aluminium heads. Be sure and use a little RTV around the water ports on your heads on both sides of your gaskets. Just a tiny amount on tour finger and wipe it around the openings on the head and block. Also, don't forget about the gasket orientation.
I found this to be a huge advantage on FE's.
Clois
"Let's roll"
"Be part of Something Good
01-04-2010, 10:31 AM
OR
Good luck!!
I can burp with the best of them by now!
ERA FIA 2088
01-04-2010, 01:39 PM
I've always found the SBFs to be a biatch to burp in my FFR. Mostly I think due to the radiator top laying down lower than the goose neck/filler. I installed petcocks at the rear end of the intake manifold to make burping easier. A friend who has a 289 in his TVR recommended the surgery. Works like a charm. I was amazed at how much air was trapped at the rear cooling channels. No crossover on the rear of this Edelbrock intake. The Tupperware air cleaner is a bit restrictive though.
01-04-2010, 02:18 PM
OR
That's not a bad idea. Luckily I have them there Webers & a pretty decent radiator height. Definitely something to keep in the back of my mind for future projects, though!
ERA FIA 2088
01-08-2010, 08:03 AM
What type torque wrench are you using?
01-08-2010, 08:05 AM
Probably a "click-type" that has been repeatedly dropped on the cement floor and, on at least one occasion, used as a hammer to tap in a couple of finishing nails that backed out....
01-08-2010, 08:47 AM
OR
It's a quality piece, can't remember the name but we tested it with a Snap On that had been recently calibrated.
ERA FIA 2088
01-08-2010, 11:49 AM
OR
Is that bad for it?
ERA FIA 2088
01-08-2010, 11:51 AM
Originally Posted by *13*
Is that bad for it?
Yeah, the click types are pretty sensitive. I've dropped them before and gotten them way out of whack. They can be re-calibrated though. I prefer them to the pointer type, other folks say just the opposite.
01-08-2010, 11:57 AM
OR
I was being funny, of course....I can be pretty rough on tools but not precision instruments. It tend baby them I tuck them away in a safe place when not in use
ERA FIA 2088
01-08-2010, 12:00 PM
I know, but the problem is that six months from now a guy reads posts like this and can't tell that we were joking. I got an email a month or two ago from somebody asking me to clarify how do something that I had posted that was clearly a joke. I actually felt bad for leaving an un-clarified joke instruction in a post. It wasn't quite as bad as "have your friend hold the coil wire against his tongue while you crank the engine," but it was close (at least in my mind).
01-08-2010, 12:04 PM
OR
That would be a great YouTube video!
ERA FIA 2088
01-08-2010, 12:06 PM
Hmmmm, maybe I can pull that one on RodKnock....
01-08-2010, 12:28 PM
va
So any way, how does the engine run now?
01-08-2010, 12:35 PM
OR
Seems OK. We'll fnd out tomorrow. I got her buttoned up, retorqued & took her around the block a couple times. I plan to get out for a few miles in the morn.
ERA FIA 2088
