  #21 (permalink)
Old 01-02-2010, 09:18 AM
Send a message via MSN to CowtownCobra
I've had the best luck in torqueing head bolts when I wait for the ambient temp to hit <32 degs, then torque away. Give it a try
  #22 (permalink)
Old 01-02-2010, 09:29 AM
*13*'s Avatar
Where did I puy that freon spray...
ERA FIA 2088
  #23 (permalink)
Old 01-04-2010, 12:29 AM
PANAVIA's Avatar
Sounds like you are on the right pathway , could just be a gasket.
if it happens again , then i would say you have a potato chipped shapped cylinder surface or head surface.
  #24 (permalink)
Old 01-04-2010, 06:31 AM
*13*'s Avatar
Thanks guys! I got her all buttoned back up yesterday morning. We'll see what happens...
ERA FIA 2088
  #25 (permalink)
Old 01-04-2010, 09:50 AM
TButtrick's Avatar
Make sure it's burped well!
Good luck!!
  #26 (permalink)
Old 01-04-2010, 09:56 AM
Clois Harlan's Avatar
[QUOTE
maybe a warm up and a retorque could have preventad this???????[/quote]
This is key especially when you are running Aluminium heads. Be sure and use a little RTV around the water ports on your heads on both sides of your gaskets. Just a tiny amount on tour finger and wipe it around the openings on the head and block. Also, don't forget about the gasket orientation.
I found this to be a huge advantage on FE's.
Clois
"Let's roll"
"Be part of Something Good
  #27 (permalink)
Old 01-04-2010, 10:31 AM
*13*'s Avatar
Good luck!!
I can burp with the best of them by now!
ERA FIA 2088
  #28 (permalink)
Old 01-04-2010, 01:39 PM
TButtrick's Avatar
I've always found the SBFs to be a biatch to burp in my FFR. Mostly I think due to the radiator top laying down lower than the goose neck/filler. I installed petcocks at the rear end of the intake manifold to make burping easier. A friend who has a 289 in his TVR recommended the surgery. Works like a charm. I was amazed at how much air was trapped at the rear cooling channels. No crossover on the rear of this Edelbrock intake. The Tupperware air cleaner is a bit restrictive though.
  #29 (permalink)
Old 01-04-2010, 02:18 PM
*13*'s Avatar
That's not a bad idea. Luckily I have them there Webers & a pretty decent radiator height. Definitely something to keep in the back of my mind for future projects, though!
ERA FIA 2088
  #30 (permalink)
Old 01-08-2010, 08:03 AM
What type torque wrench are you using?
  #31 (permalink)
Old 01-08-2010, 08:05 AM
Probably a "click-type" that has been repeatedly dropped on the cement floor and, on at least one occasion, used as a hammer to tap in a couple of finishing nails that backed out....
  #32 (permalink)
Old 01-08-2010, 08:47 AM
*13*'s Avatar
It's a quality piece, can't remember the name but we tested it with a Snap On that had been recently calibrated.
ERA FIA 2088
  #33 (permalink)
Old 01-08-2010, 11:49 AM
*13*'s Avatar
Is that bad for it?
ERA FIA 2088
  #34 (permalink)
Old 01-08-2010, 11:51 AM
Originally Posted by *13* View Post
Is that bad for it?
Yeah, the click types are pretty sensitive. I've dropped them before and gotten them way out of whack. They can be re-calibrated though. I prefer them to the pointer type, other folks say just the opposite.
  #35 (permalink)
Old 01-08-2010, 11:57 AM
*13*'s Avatar
I was being funny, of course....I can be pretty rough on tools but not precision instruments. It tend baby them I tuck them away in a safe place when not in use
ERA FIA 2088
  #36 (permalink)
Old 01-08-2010, 12:00 PM
I know, but the problem is that six months from now a guy reads posts like this and can't tell that we were joking. I got an email a month or two ago from somebody asking me to clarify how do something that I had posted that was clearly a joke. I actually felt bad for leaving an un-clarified joke instruction in a post. It wasn't quite as bad as "have your friend hold the coil wire against his tongue while you crank the engine," but it was close (at least in my mind).
  #37 (permalink)
Old 01-08-2010, 12:04 PM
*13*'s Avatar
That would be a great YouTube video!
ERA FIA 2088
  #38 (permalink)
Old 01-08-2010, 12:06 PM
Hmmmm, maybe I can pull that one on RodKnock....
  #39 (permalink)
Old 01-08-2010, 12:28 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
So any way, how does the engine run now?
  #40 (permalink)
Old 01-08-2010, 12:35 PM
*13*'s Avatar
Seems OK. We'll fnd out tomorrow. I got her buttoned up, retorqued & took her around the block a couple times. I plan to get out for a few miles in the morn.
ERA FIA 2088
