  #41 (permalink)
Old 01-08-2010, 12:55 PM
TButtrick's Avatar
Don't forget to retorque the muffler bearings. 75 ft/lbs in 1 ft/lb increments.
  #42 (permalink)
Old 01-08-2010, 02:08 PM
*13*'s Avatar
I tightened those in Inch Lbs using a 60" cheater bar
ERA FIA 2088
  #43 (permalink)
Old 01-08-2010, 03:48 PM
A very important step with the click type torque wrench is to back the adjustment off to "0" when finished. This will unload the spring and maintain the accuracy indefinitely if used infrequently.
But also good to re-calibrate occasionally if heavy use.
Craig
  #44 (permalink)
Old 01-08-2010, 07:48 PM
YerDugliness's Avatar
Craig
I own a few Craftsman "click type" torque wrenches, use them very infrequently. I usually do back the adjustment off to "0", but I would like to have the calibration checked, anyway, since it's been about 5 years since I used them.
How/where does one go about getting them recalibrated?
Thanks!
I sure hope the head gasket job does the trick for you. One thing I learned from a V-6 Olds Cutlass, you really need to check for warped heads if the engine ever got hot......after replacing the same head gasket for the 3rd time I took the heads to a machine shop to be "shaved", never had the problem again.
Dugly
YD,E./PNB
  #45 (permalink)
Old 01-08-2010, 08:15 PM
Dugly
The original manufacturer will usually re-calibrate.
Craig
  #46 (permalink)
Old 01-09-2010, 04:00 AM
Default Pat you are SERIOUS?????
patrickt With 10,000+ posts and you are serious? Funny,Nasty, Grumpy, Silly, Dippy, even 2 sheets to the wind. SORRY serious and you on this forum doesn't work. Ask Undy Hope you and the family had a good holiday. Rick L.
  #47 (permalink)
Old 01-09-2010, 05:04 AM
Rick, just plant yer kisser right on this here coil wire for me....
  #48 (permalink)
Old 01-11-2010, 08:38 PM
Ralphy's Avatar
This thread reminds me of a discussion at another board. It was in regard to TTY head bolts.
http://www.enginebuildermag.com/Arti..._bolt_use.aspx
  #49 (permalink)
Old 01-16-2010, 08:13 AM
*13*'s Avatar
So 2 final results. #1 I don't get enough time to spend with the car. #2 Head gasket situation is good. Everything is operating normal! Now back to tuning carburetors....
Originally Posted by cobrakiwi View Post
So any way, how does the engine run now?
ERA FIA 2088
  #50 (permalink)
Old 01-16-2010, 05:13 PM
TButtrick's Avatar
Great article. Thanks.
  #51 (permalink)
Old 02-11-2010, 08:47 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Actually you can calibrate your click type torque wrench. They usually have screw or allen screw in the end or the side. You can put an old socket in a vise, put the torque wrench in the socket, then hang from a cable or coat hanger on the handle various weights to check against what you have it set at. If should click just a you lightly set the weight on. Then move the tool to a slightly higher weight and it should not click.
