Old 04-11-2010, 06:05 PM
Cobra Make, Engine: ERA FIA #2128
Default 351 vs 289 Dual Plane Firing Order
As the firing orders are different, will the Blue Thunder 289 Cobra Hi Rise dual plane manifold give maximum performance on a 302 block with a stroker crank that uses the 351 firing order? In theory dual plane runners are sequential so as each intake runner is 180 degrees apart in the firing order. I know it will fit, it's just getting maximum flow that concerns me.
Old 04-12-2010, 09:41 PM
It should work fine with the 351W firing order which is what most of the cams are using now.
Good luck, Keith
Keith C
Old 04-12-2010, 11:21 PM
PANAVIA's Avatar
If you are really concerned , you could put in dual O2 sensors and check for exhaust gas readings.
idle , off idle , 1000,1500,2000, -- - -on up.
Steve
Old 04-13-2010, 07:08 AM
Default Thanks
Thanks to both. Steve, you're right. I should do that as it will tell if pulse reversion is starving certain banks/cylinders.
Old 04-13-2010, 07:18 AM
Jerry Clayton's Avatar
so will a plug check---no welding, no buying more parts/tools that cost more than the cam/manifold
