Old 07-23-2010, 08:07 AM
Z-linkCobra's Avatar
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Its generaly spark or fuel related. Have you checked the valve lash? Might want to pull the valve covers and just give them a once over to eliminate that possibility.
If the lash was too tight then that might cause a valve to hang open a little and give you grief with reflux at the lower rpms. If it was to loose then it can retard the valve timing and give you a backfire through the exhaust...Im just thinking out loud really. Just something to look at.
" If it wont break em loose in 3rd gear, it aint enough power "
Rate This Thread:
