Old 09-04-2010, 10:20 PM
LMH's Avatar
LMH LMH is offline
Default Final Machine Work on A Dart Block
Hey all,
What kind of finish machine work is required on a new Dart block before assembly?
Comparing cost of machine work on my production 351W block to that of a 351W Dart block.
Alba gu brąth
Old 09-05-2010, 04:42 AM
PANAVIA's Avatar
It depends on the finished product you are aiming for >?
is there a stroker kit involved > ?
Old 09-05-2010, 04:51 AM
They're already clearanced for stroker kits.
Depending on the bore you want, you'll either need to finish hone, or bore/hone, and square deck to the deck height that you need. If you switch to main studs, you will need to align hone as well.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 09-05-2010, 07:30 AM
LMH's Avatar
LMH LMH is offline
Thanks guys. Will be 4" stroke either block, nothing outlandish.
Alba gu brąth
Old 09-05-2010, 07:55 AM
Jerry Clayton's Avatar
I'm leaving Illinois for a trip out rt 66 with sides to Carlsbad, Pheonix, Grand Canyon--Want me to bring you one? They come about .010 under on the bores for sizing to the pistons used--the shp blocks are lighter than the regular series and you can get them at 4.125(undersize for clean up) which with the 4.000 stroke does the number ---
You can go bigger but you cut down the number of rebuilds you can do--
Old 09-06-2010, 02:51 PM
LMH's Avatar
LMH LMH is offline
Jerry, got an idea on price?
Alba gu brąth
