  #21 (permalink)
Old 10-18-2010, 08:23 AM
Jerry Clayton's Avatar
Over my years of racing everything from top fuelers, funny cars, pro stockers, dirt/pavement stock cars, sprint cars and indy stock blocks---I want an setup that is easy to adjust cam timing (Gear drive/Jesel belt) or even change cams quickly between rounds---sometimes this might even mean a hole in the radiator core that the cam would fit thru!!
At one time I even had all our cams ground with the same exact base circle so we didn't have to adjust the lash after a between rounds change
Bee hive springs are for car shows and cruises-----
  #22 (permalink)
Old 10-18-2010, 08:35 AM
Originally Posted by Jerry Clayton View Post
...sometimes this might even mean a hole in the radiator core that the cam would fit thru!!
LOL, I never thought about doing that....that's awesome....
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
  #23 (permalink)
Old 10-24-2010, 11:56 AM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
Beehives: never to be used on a solid roller/ radical ramp cam. Alot of engine builders say so; I dunno...
On the iron/ iron VS alu/ iron VS alu/ alu heads/ block. As used to the first mentioned and a little more than advertised lash while cold, I was a bit shocked when I experienced the last type; have to be set TIGHTER to be correct at warm.
I think .015 @ cold and .020 warm....
Rate This Thread:
