10-08-2010, 08:19 PM
Originally Posted by JST4FUN
Patrickt, how much oil do you hold back to compensate for whats held in the cooler?
Well I don't hold any back. My system ends up needing about 8.5 qts, and what I do is drain my oil, fill the filter up and put it on, then put in 7 quarts, run the engine for a little bit to make sure there are no leaks, then stop it and rest for a while, then go back and top it off up to the "FULL" mark on my dipstick. All in all it takes about 8 and a half bottles to do that.
10-08-2010, 09:44 PM
AL
Cobra Make, Engine: SOLD-SPO2660, Southern Automotive 406FE, TKO-600
Thanks, I'll use that approach! I've got my first one coming up pretty soon.
Joe
Have fun and enjoy life, because when it is over, it is too late!
10-09-2010, 04:46 PM
Ky
Cobra Make, Engine: Superformance MK III 428CJ
Just purchased Superformance MKIII which has a 428CJ.
Just talked to the engine builder yesterday, he says the engine has everything done to it and i guess still run on pump gas?
Built 5 years and 7K miles ago, alum heads, intake, waterpump and flywheel.
Internaly balanced, ported, port matched, melling oil pump, 10.6 to 1 I think.
Oh yes and solid lifter flat tappet cam about as big as you would ever want for street i guess.
The quistion is, it has always run Pennsoil 50 wt racing oil and he says don't change to anythink else?
I'm not real fond of Pennsoil, cannot find anything close by except Valvoline racing V-1 or something?
I have an old Bluebird that uses 40W rotella and was wondering how that compares to racing oil?
thanks
marvin
10-09-2010, 04:47 PM
Ky
I forgot, it holds 12 qts with filter and holds lots of oil pressure, hot or cold.
marvin
10-09-2010, 05:23 PM
MD
Brad Penn 20w-50. Fred (FWB) on this forum can send it to you at a decent price. Plus you get to support a fellow CC member.
www.partskeeper.com
10-09-2010, 05:27 PM
Surely he meant Pennzoil's 25w-50 racing oil. Considering he built it, and it's made it this far with a solid flat tappet, I'd listen to him. You might just check that the oil still has sufficient ZDDP in it (it's bound to, but it doesn't hurt to check). You can get that oil shipped to you from a variety of sources on the internet.
