View Poll Results: What shaft mounted rockers would you choose?
Harland Sharp 1 7.69%
Jesel Sportsman 7 53.85%
Doesn't matter; both are up to the job 3 23.08%
None of the above; they're too weak! 2 15.38%
Voters: 13. You may not vote on this poll
Old 11-19-2010, 01:02 AM
Caprimaniac's Avatar
Cobra Make, Engine: Unfortunataly ; none
Default Any input on what shaft mounted rockers to use?
For a 347 with Victor Jr. heads; which of the three options would you pick?
Please VOTE!
The new shaft mounts with stainless steel rockers is my favourite, although in the adds there is much focus on top fuel and "really harsh" racing environment for these rockers.
I'm currently using the Comp Cams stainless steel roller rockers on 7/16 studs, and it seems to work very well.
Will any of these aluminium rocker options be a good choice, and is there anything that makes one better than the other?
Post this poll simply because I have no 1. hand experience on shaft mounts and have few others to ask, besides from you, great lot! Use is mild solid roller cam (0.64" lift, 300 duration, up to 7500- 8000 rpm). did some searches and read quite alot without finding a favourite amongst the two poll options. Last list of parts I used were simply put together by manufacturers choice and my own eyes staring at the the glossy catalogue pages...
RS
Rate This Thread:
