Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
  #61 (permalink)
Old 04-22-2011, 11:46 PM
Ant Ant is offline
Default 427w
Originally Posted by SwiftDB4 View Post
Thanks for the reply Ant. I'm always amazed by you Kiwis. Any country with a Burt Munro has lots of mechanical knowhow. How's Christchurch doing?
I live 50 mile south of Christchurch and go to work at Christchurch Mens Prison just outside the city. The centre of christchurch is like a bomb site, there are still a lot of buildings that are to dangerous to enter. Japan has over shadowed Christchurch with their massive amount of devastation, it doesnt lessen the impact on Christchurch and has had a massive impact on this countries finances, I guess we are all struggling with the dollars, and fortunately nobody close to me has lost their life....!
Thanks for your post.
A J. Newton
The 1960's rocked!
  #62 (permalink)
Old 04-08-2021, 11:04 AM
Default 427 Windsors
i dont think there are too many out there without forged internals and the like, my rebuilt ford racing has a forged crank, very good pistons, forged rods, the Cleveland journals, a sill big juice cam, 4bolt mains, stout block, ported heads all of it...and it pulls HARD right ot where i lose my nerve and shift, usually about 6k...In one of these cars i really dont see a need to go beyond that. Canyon carving at around 4k is really fast with 3.23 gears and a tko 600...
Pete Munroe and hauss like this.
Superformance 1764
Built 427W
Aiken SC USA
  #63 (permalink)
Old 08-13-2021, 10:55 PM
If you run these motors to 7K, you'll kill the main bearings.
  #64 (permalink)
Old 08-14-2021, 09:44 AM
Mark, just curious why you would say that? Because it's a 3" journal? I take 3" mains on BBF's to 8500-9000.
Although most guys are using 2.750" mains on Windsors these days, I would have no issue turning some rpm with a factory block either (until you make enough horsepower that the block destructs....)
  #65 (permalink)
Old 08-14-2021, 01:29 PM
eschaider's Avatar
Originally Posted by fordracing65 View Post
... Should take me a few months to put together then dyno i will post results then, thanks for any advice.
What happened to the dyno results that were going to be posted up in a few months 10 years ago??
Ed
  #66 (permalink)
Old 08-15-2021, 12:14 AM
The 3.000 Windsors get cap walk when you get much over 6,200. The Cleveland mains are fine....but it's no longer a Windsor block.
  #67 (permalink)
Old 08-15-2021, 04:10 AM
I agree, as a whole, the factory blocks can often be found lacking. It seems it's a craps shoot though, as to which one will fail. I've seen 600+ hp factory block 347's and then I've seen 500 hp 347's split down the middle.
I've seen a few guys running 3.85" and 4" strokes on factory 351W blocks turning some rpms without issue, but I think the general movement for performance oriented builds has went toward the aftermarket blocks.
I was trying to remember if I had built any factory block Windsors turning some rpm, but none come to mind. They all are aftermarket block builds.
  #68 (permalink)
Old 08-15-2021, 10:41 PM
But.......back in the day........
We used to ship three or four 408/427 Windsors a day for the replicas. The mains aren't really much of an issue with them because very few replicas get over 6000 rpm without the lunatic driving it getting arrested. My Superformance car had a 635 H/P 418 in it and, frankly, it could be a bit of a handful.
The drag racers consistently saw the problem with the mains, usually up around 700H/P and above 6,800.
We still do a fair number for stock block engines, but it is moving toward aftermarket blocks....when we can get them. And that isn't now.
  #69 (permalink)
Old 08-16-2021, 09:24 AM
I can't get squat now. Just received 5 sets of custom pistons that I've had on order since April and every. single. set. had. something. wrong.
  #70 (permalink)
Old 08-17-2021, 12:45 AM
That is why I write my own job cards...and why I pretty much stick with ROSS.
  #71 (permalink)
Old 07-19-2023, 02:38 PM
Cobra Make, Engine: Midstates 427" Stroker Smallblock with Trick flow heads
Generally you'd need a pretty big cam, induction and cylinder head for a 427W to be even remotely happy up there around 7000.
Something like a CHI Clevor head and intake with about 340 cfm of flow on the intake with a 260-ish @ .050 solid roller and .650-.670 lift would make peak power around 6500-6700 rpm and rev past 7000 pretty easily. and 11.5:1 is pretty normal for that type of build....so unless you're building a race specific car, I'd want to keep the torque and power in the more comfortable 4000-4200 peak FPS max of piston speed.
But generally....torque motors make good torque and roll-on power due to long strokes and faster piston speeds through the mid range. After the torque peak the piston rings, springs and bearings start to act like a friction brake, and the longer the stroke the more you have to coerce a torque motor to act like a Horspower motor, generally if you desire that kind of RPM I'd go shorter stroke where the internal frictional losses per each 100 rpm gain above the torque peak make the engine more efficient.
you probably could rev a not-High RPM purpose built 427 combo that high in a cobra, after all 2500 pounds isn't hard to push...but you'd just be abusing the internals in a not very 'happy" way. 5700-6200 is at the high side of a strokers "happy place" and winding out to 6700 or a little more through the traps at the track is only for a few seconds.
Better IMO to build a more mild motor, keep the internals more mild (the extra valvespring pressures and cam lobe profiles you need arent very efficient for cruising at 2400-3000 rpm after all) And just because you can doesn't mean you should. There's something to be said for not needing race type spring pressures and still making more power than you could ever need...and needing much less gear to do so.
A 3.25" stroke 331 tuned to make peak power at 8000 has the same piston speed as a 4" stroke 427 at 6500, so your piston travel/friction(heat) on the cylinder walls with a 427 @ 7000 is like a 331 turning over 8600, and the side-loading is higher too because of the increased rod angularity and longer bores.
I built my 427W (stock 351W block 4.04" bore and 4.17" stroke) with highly ported TFS Twisted Wedge heads and ported Motorsports Victor JR) to basically emulate the power curve of a street 427FE ....so I keep the revs to 5800-6000 but it'll rev to 6500, the natural peak power is probably around 5200 and the torque is absolutely wall-to-wall. I wouldn't push mine to 7K because I didn't valvespring it and cam it for that kind of RPM. I wanted that fat upper bottom and mid range sledgehammer torque like an FE...without the weight. It certainly doesn't lack for acceleration and my torque is impressive in any gear withing the limits of the RPM. my 427 was the very first stroker kit Coast High performance actually sold, and the 340 mopar rods had to be clearance so as not to interfere with the cam lobes, so I wish I had waited for the kits to catch-on, so I could have used H beam rods that allowed for larger cams and far less "trial fitting" during assembly.
Nonetheless I am extremely happy with the results.
BTW....I really enjoy all of Mr. Lykins' posts here, he is very informative and generous with his sharing of knowledge.
Wize
  #72 (permalink)
Old 07-21-2023, 12:54 AM
Dominik's Avatar
If it is only about the sound of 7.000 rpm, why don't you build a smaller V8?
