12-09-2011, 04:00 PM
Cobra Make, Engine: SPO 1967 / Roush 402R
Looking for the definite answer on valve covers and roller rockers
My SPO came with a Roush 402R built from the Dart / 351W block. After hours of searching this forum and others, I am still in the dark about which aftermarket valve covers will fit without spacers.
The "tall" covers from Cobranda apparently don't fit (per my telephone call), even though the website says yes. Other posts seem to suggest that Ford's new line of valve covers will fit, even though their descriptions say that "some modification may be necessary to clear roller rockers."
Specifically, I would like to match my traditional black oval air cleaner with the finned black covers that say COBRA on them, but I'd hate to eat $150 - $200 getting the wrong ones (or having to buy them, then get spacers after all).
Any leads?
Thanks in advance,
12-09-2011, 05:54 PM
Cobra Make, Engine: CSX 7030 HP 289
I'll weigh in. I'm using Branda's "tall" covers with Comp Cams steel roller rockers; there's no interference. FWIW. Cheers, Tom
12-09-2011, 06:39 PM
TN
Cobra Make, Engine: SPF, 418 Stroker
Try these: Cobra Valley's S/T Small Block Valve Covers
Note that they are available in different finishes.
I tried the Branda tall valve covers on my 420W which has stud girdles and they would not fit. I think they would have been tall enough except for the stud girdles.
As for the definitive answer, try this. Take some measurements on your valve train or your current valve covers to see height you need. Measure say, from across the gasket flanges to the bottom of the baffle. Then compare that to the same dimension on any new valve covers you're considering.
12-09-2011, 06:41 PM
Backdraft Racing Dealer
Post part numbers.
12-09-2011, 07:38 PM
Here's an example of a cover listed on several sites that says it will clear. I can measure, of course, but the hard part is getting an inside measurement of a potential part off the web.
Ford Racing #397-M-6582-F302
Thanks for the tips.
12-09-2011, 07:57 PM
TN
Benzito, you might try searching eBay for "Tall 351W valve covers", or a similar search. If you find something you like, you can then ask the seller to give you the flange to baffle measurement, if it's not already listed. I've had good responses from sellers there.
12-09-2011, 09:09 PM
I have the spacers. No issues. Most people don't even notice them. I have the finned "Cobra" valve covers. See my gallery for pics.
DD
Dangerous Doug
"You're kidding, right?"
12-09-2011, 09:22 PM
The fly in the ointment is the baffle plate under the pcv valve hole on one cover and breather tube on the other. Different heads have the the gasket rails at different levels thus placing the valve covers higher or lower. Take some vertical measurements of the highest point of the rocker at full lift or the adjuster nut in relation to the gasket rail then get a rocker cover that will accept that dimension. Tweak acordingly. Sometimes a high quality 5/16 thick gasket will add just enough.
12-10-2011, 07:17 AM
12-10-2011, 07:30 AM
mo
Those are the covers we use also but we run a Jessel shaft system for our rollers.
  I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
12-10-2011, 12:03 PM
WA
Cobra Make, Engine: SPF2089
The cobra Valley covers worked for me.
dblbarrel
12-10-2011, 01:25 PM
OR
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
Originally Posted by Cashburn
I also use those valve covers. Dart heads, Comp roller rockers.
12-10-2011, 02:22 PM
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
12-10-2011, 04:37 PM
I replaced my Roush valve covers with the flat black ford valve covers that say
Cobra on them. No clearance problems.
12-22-2011, 12:43 AM
No
Hi.
I've used these Ford Racing M-6582-F302 - Ford Racing Aluminum Valve Covers - Overview - SummitRacing.com stock height covers with 0.2" rubber gaskets, 0.6" valve lift & 1.6 ratio (Comp steel) RR's. No problem.
However- when the RR's were replaced with Jesel shafts, it was a tight fit... I had to grind off some "warts" (some kind off threaded pidestals for shielding cover) and give the splash shields a couple of bangs with the hammer. Worked well in the end.
RS
12-22-2011, 03:07 AM
Ont
Benzito
I have a 402R Roush in my SPF and I used these rocker covers from Ford Racing.
Part # M-6582-W427B
Ford Racing Performance Parts
Stu
