Like Tree1Likes
Old 03-20-2012, 01:26 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Incidentally, in the 400hp 302 article, in the fourth paragraph they state that all they did (other than the AFR 165's and the 1.7 rockers) was a "a quick bottle brush hone to clean up the cylinder walls and a set of fresh rings and bearings".
Perhaps I'm not the laughable lunatic all of you seemed to think I am.
DD
Dangerous Doug
"You're kidding, right?"
Old 03-20-2012, 06:10 PM
DD
I guess I'll start building my engines that way....that should save me a ton of money! Trust me Doug, I write for quite a few magazines and they don't have the budget to throw copious amounts of money at machine work and parts. As a matter of fact, if they didn't get a lot of parts donated to them by the manufacturers, or the articles weren't written about a certain build that an outside builder was doing, they probably wouldn't get very far.
As for the cylinder heads, increased displacement is the key factor there. Those 185 heads are excellent choices for 347's, 351's, some 408's, etc. I've found that customers want to go overboard on heads, carbs, and cams. Bigger is not always better...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 03-31-2012, 07:09 PM
PoppyMod's Avatar
Cobra Make, Engine: Ford 289
Hi,
Very, very true regarding the heads! Once you decide what you expect from your build, the heads will be the next most important decision. Because they become the introduction of your engines breathing capabilities. If this is a street warrior, build for torque. Don't get caught up in the hype that bigger is better. On the street bigger is better, as it applies to torque.
Just my 2 cents.
Ken
Severna Park, Md
